CX500 Rust on swing arm
griffonmel
PostPosted: 17:08 - 18 Oct 2015    Post subject: CX500 Rust on swing arm Reply with quote
Hi Guy's,
I have a CX500 I am rebuilding to a Cafe racer theme. I have just stripped it all down, needs a good clean as usual or should I say a major one! Checked all over main frame is good just some basic surface rust, been tapping away with hammer and screwdriver to be sure! However a I found some rust through on swing arm, not to bad as I can see, solid all around holes. Do you all think this can be sorted out via weld repair?
Cheers, Mel.
Robby
Dirty Old Man
PostPosted: 19:11 - 18 Oct 2015    Post subject: Reply with quote
It's a fairly common place for old steel swingarms to rot out. The usual repair would be cut out the rotten and thin metal and weld on a new patch. I would remove the whole section - it gets thin - and replace with new metal.
blurredman
PostPosted: 22:57 - 18 Oct 2015    Post subject: Reply with quote
Yes. My CX lately had to have 10 weld patches in various areas of the frame and swingarm. Here are a few pictures:
ftp://blurredmanswebsite.ddns.net/Pictures/bikes/cx/rsz_dsc_0411.jpg
ftp://blurredmanswebsite.ddns.net/Pictures/bikes/cx/rsz_dsc_0412.jpg
There were other holes, including of the swingarm. The hole on your swingarm is not the same place as where mine were (oddly enough on the face that points to the swingarm pivoter (?), but it's handy that it's in a flat place means it is even easier for a welder to fix.
It got bigger as I prodded more, notice how thin the metal is though, and that is a mirrored issue in your picture. Typical not of just the CX but a lot of older bikes. Like I said, no biggy to fix.
https://blurredmanswebsite.ddns.net/pictures/bikes/cx/20150815/swingarmhole.JPG
WD Forte
PostPosted: 00:43 - 19 Oct 2015    Post subject: Reply with quote
CX500?
Rubbish!
Just burn it and buy a proper bike
bikers smell of wee
davebike
PostPosted: 08:50 - 19 Oct 2015    Post subject: Reply with quote
Welded lots of CX500 swing arms common problem
You NEED to brace the end of the arm when welding replace the Drive box get a thick a piece of studding that will fit the wheel spindle hole fit with nuts on both inside and outside maintaining the arm width
I personally just plate the outside of the damaged areas Then drill a small hole and use ACF50 or similar on the inside
Paint the outside with smoothrite and it good to go
The Temporary bracing is very necessary
Dave
NC750Xdct + others at work !
[email protected]
RhynoCZ
PostPosted: 10:00 - 19 Oct 2015    Post subject: Reply with quote
The disadvantage of a shaft drive is, that you can't just swap the swing arm for anything but the original one. Thumbs Down
I think it is time to buy a new bike.
The last post was made 11 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 49.23 Kb
