2 Questions - Indicators and Bar weights
Gazz
PostPosted: 21:34 - 18 Oct 2015    Post subject: 2 Questions - Indicators and Bar weights Reply with quote
Don't really have a problem as such at the moment but I can foresee some coming.
Recently I have purchased a set of hand guards for my dirtbike for some wind protection over winter, but on fitting them they cover the indicators, so I was thinking of getting a new set of indicators but found this on ebay instead:
https://www.ebay.co.uk/itm/Strips-LED-amber-indicator-marker-lights-leds-3-SMD-x2-/151312572882?hash=item233aeea1d2:m:mn3u8Coqgtu_J-k6aEXE50g
https://i1101.photobucket.com/albums/g429/abbones1/led%20strips%203smd/DSCF5223_zpsnv802mqz.jpg
https://i1101.photobucket.com/albums/g429/abbones1/led%20strips%203smd/DSCF2553.jpg
Would they just wire up to my existing wires for the orignal indicators? Or would I need to get something else too because they are LEDs?
And my second issue is (without riding the bike with the hand guards fitted) am I likely to notice any issues with the bar end weights removed? I never realised that they weighed such a considerable weight before I removed them to fit the hand guards - which have a plastic inside where the original weights went.
And if so, is there anything that you can think of that would add addition weight to them?
Itchy
PostPosted: 21:44 - 18 Oct 2015    Post subject: Reply with quote
If you leave the old indicators spliced in they will provide the necessary resistance to make them flash at a normal rate.
Or you could just change the indicator relay which is a £3 jobbie if you use a car one. Most are a three pin design.
Removing weights will cause additional vibration through the bars. Even IL4 and twins which are supposed to cancel out the vibrations by firing order get vibes through the bars. The Kawaka Z750 I tried had awful vibes. Since you said dirt bike which makes me think big single or twin. It'll make it vibe a lot.
Nothing stops you from fitting the weights on the outside of the hand covers.
PostPosted: 10:44 - 19 Oct 2015    Post subject: Reply with quote
£5 for a suitable relay
https://www.ebay.co.uk/itm/PRO-12V-FLASHER-2-PINS-RELAY-BLUE-FOR-MOTORCYCLE-MOTORBIKE-LED-INDICATORS-Z035-/170873685070?ssPageName=ADME:L:OC:GB:3160
Filling the bars with silicone sealant apparently helps with vibes. Bit of hose on the end of the nozzle, start spurting in the middle and work outwards.
The last post was made 11 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 38.31 Kb
