o2 sensor eliminator
andyd87
PostPosted: 11:51 - 19 Oct 2015    Post subject: o2 sensor eliminator Reply with quote
I've had my first bike, a GSR 600, for a few weeks now and really enjoying it. The only niggle i have is that the throttle can be a bit snatchy/jerky sometimes no matter how gentle I am with it.
I have had a look online and it seems to be normal on these and a power commander or o2 sensor eliminator seems to fix it.
Being a tight git I have been looking at this-
https://www.ebay.co.uk/itm/Oxygen-lambda-o2-sensor-eliminator-Suzuki-GSR-600-all-/260961311577
If i tried this is it likely to cause any other problems or is it really as simple as the listing suggests?
Thanks,
Andy
PostPosted: 12:07 - 19 Oct 2015    Post subject: Re: o2 sensor eliminator Reply with quote
It's really intended for use with a Power Commander to set up a new fuelling map. You won't know what the default fuelling is like unless you're prepared to do plug chops or take it in for a dyno/EGA run.
If it runs too lean you'll overheat, if it runs too rich you'll foul the plugs and wash the bores.
How much do you trust Suzuki's default map?
andyd87
PostPosted: 15:14 - 20 Oct 2015    Post subject: Reply with quote
I thought it may not be that simple. its not a major problem so I can learn to live with it for a while till I upgrade my bike.
Thanks for the help
The last post was made 11 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 36.13 Kb
