Pilot Road 4 Vs Pilot Street Radial
PostPosted: 18:42 - 19 Oct 2015    Post subject: Pilot Road 4 Vs Pilot Street Radial Reply with quote
I have two identical bikes (BMW R1100s), one I bought shod with pilot road 4's the other came with Bridgestones I think but near the end of their life so I fitted it with Michelin Pilot Street Radials after talking to Chris at FWR.
I bought the Street Radials around April/May this year as I wanted a tyre with decent longevity, and I figured that I could wear them out through summer and switch to a more premium tyre for winter. I had found that the tyres tracked and turned well with very light inputs but I felt that the carcass was a bit on the stiff side and transmitted every tiny bump and stone through the suspension. I also found that the back brake would lock up very easily in the damp and tend to skip and slide on rough down-changes. I figured that might improve once they were worn in but they didn't seem to get much better after a few hundred miles.
Well I crashed that bike and it's been sat in my garden all summer. The replacement bike came with Pilot Road 4 tyres with loads of life on them. I was impressed by the immediate improvement in feedback of the PR4's and totally different rear-end behaviour to the Street Radials. Just recently the bike has been getting very squirmy over lines as the tyres are just about worn out so I've started looking at replacements.
This weekend I noticed that the front was almost bald on the sides, worn like a pyramid with the peak chopped off so I whipped the wheels off the dead bike and swapped them over to my current one. The light handling has come back with the tyres being barely worn but now on this other bike the Street Radials are performing better than on the other with no nasty little slips on the rear brake.
So now I'm torn. I have to replace my tyres but can't decide between £150 for a pair of Street Radials or £250 for Pilot Road 4's. The Street Radials are a nice enough tyre to ride on but you do feel the road surface a lot more and I'm concerned about their ability to retain heat in the cold and wet. That said, I've no idea how the PR4's perform in winter so will they be any better, or at least better to the tune of an extra £100.
What say you , BCF massif?
SQL
PostPosted: 18:46 - 19 Oct 2015    Post subject: Reply with quote
I love my PR4's on the MT I don't really change my riding style when its wet either, I am looking forward to testing in winter but no nasty suprises yet.
PostPosted: 18:55 - 19 Oct 2015    Post subject: Reply with quote
I had a similar experience when I bought my Buell. I have Pirelli Diablo Rosso Corsas on my Street Triple, and they've been on there for a couple of years. The front end has cupped badly and the rear is just starting to square, even though there's still plenty of wear left. Then I bought the Buell which had Maxxis tyres on them. I expected them to be crap, but actually they feel great. Confidence inspiring even though they have a harsh profile. I do like Pirellis, and I always have since I first had them on a bike, but I'm surprised to say I'd definitely recommend the Maxxis tyres.
Slacker24seve...
PostPosted: 19:02 - 19 Oct 2015    Post subject: Reply with quote
Wouldn't the abnormal wear suggest a problem with your suspenders?
Banger rallies are ace
PostPosted: 19:04 - 19 Oct 2015    Post subject: Reply with quote
Again, another happy PR4 user here. The PR4 GT to be precise. Next time I'll go for the Standard PR4 as these GTs seem a little on the stiff side without a pillion or luggage.
They're a bazzin' tyre.
I still prefer the old PR2 but reckon NOS isn't the way to go with tyres.
MarkJ
Pilot Road 4s (and 3s for that matter) are 'good' in winter from experience. You can still spin them up as it's cold but they're a lot better than some tyres I've used in the past. While the PR4s might be £100 more expensive, how many more miles are you likeley to get out of them? I'm on something like 6-7000 miles on my set now, tread depth just under 2mm.
The centre compound on the PR4 is a lot harder than the edges, so if you do a fair bit of fun miles you might end up with a tall centre band that steeply drops away as it moves into the softer compound. Motorway commuting has sorted that out for me though Laughing
PostPosted: 19:11 - 19 Oct 2015    Post subject: Reply with quote
What abnormal wear? All my front tyres wear triangle-shaped Smile
PostPosted: 19:16 - 19 Oct 2015    Post subject: Reply with quote
So general opinion is that the PR4 is a good tyre for cold and wet?
Can't say that I'm slagging off the Street Radial. It's a decent enough tyre and I reckon will put up an impressive mileage but there's still this nagging doubt about wet weather grip. I think I'll try dropping the pressures a bit and see if there's a change.
PostPosted: 19:20 - 19 Oct 2015    Post subject: Reply with quote
For me, yes indeed but that is now sorted. The springs in the front end were far too high a rate for my weight, so I tried to compensate with a softer tyre pressure. It sort of worked, but now the springs are right it's perfect.
PostPosted: 19:22 - 19 Oct 2015    Post subject: Reply with quote
Pete. I'm a saddo who listens to a bikers podcast hosted by bike test journos. They've mentioned the PR3 & 4 on more than one occasion and in a positive light, and they ain't sponsored so no sales tactic.
SQL
PostPosted: 19:30 - 19 Oct 2015    Post subject: Reply with quote
The only issue with the pr3 I found was that the right hand side was bald completely and the left was 1-2mm left.
PostPosted: 19:33 - 19 Oct 2015    Post subject: Reply with quote
That's how mine has gone, but the opposite way round and with less of a variance. I was surprised as I would have expected the right to go first because of roundabouts.
Kaya75
PostPosted: 19:49 - 19 Oct 2015    Post subject: Reply with quote
PR4's on order for next week here, week off work so a bit of excuse.. Really time to run em in properly.. Esp after leaving the lights tonight on way home, dry and Warm day down south, backend spun up like a good'un snaking away like a boss.. Wasn't meaning to leave the last of my legal tread of some way past sell by date perilla on the Tarmac Shocked either... Had pr3 last winter on old bike, they where beautiful Wub
mentalboy
Not quite correct Pete. The PR4 is a phenomenal tyre for road use. I scrubbed in a front PR4 in that shite Devon night we had when the railway line here got washed into the sea a few years back.
I was nervous as hell taking her out in gale force winds with horizontal buckets of water and a nice fresh welly on the front, it was the worst weather I've ever ridden in, but I needed a Chinese takeaway and needs must... Wink
The tyre handled brilliantly (although I nearly dropped the bike whilst stationary when a gust of wind broadsided me!!!).
My only gripe was that the PR4's and 3's only lasted as long as the Pilot Power's and I expect a sport touring tyre to have a bit of life, especially when the old bitch used to chew them up and spit them out in under 3500 miles. I got nearly 4k out of the PR2's which were still an excellent tyre
PostPosted: 20:20 - 19 Oct 2015    Post subject: Reply with quote
Well it looks like it's PR4's then. They'll last me through to spring which should be a good test of the poor weather performance.
I hope that extra £100 is worth it - actually it's more than £100 because I usually do 2 fronts to a rear but the front has gone away first this time so I'd be buying pairs every time. That's £234 vs £480 - double the cost.
Pigeon
PostPosted: 21:09 - 19 Oct 2015    Post subject: Reply with quote
Done a year on 675 with PR4 and the last 9 months on sv650 with PR4.
They are mega, take 0.2seconds to get up to temp.
If pushed, I think during the height of summer at full chat they are not as much fun as the Rosso Corsas I had on the 675. Only because I could drift/slide the bike a bit on Rosso's which I haven't yet been able to on the PR4's I think the PR4's lack that really fine control feel that the Corsas had when they were hot.
But as 90% of the time I never went fast enough to get the Corsas hot, I much prefer the PR4's.
On the 675, managed 5,000 miles and think there is another 3k to be had.
In the damp / cold conditions, there's no comparison between the Corsas and PR4.
And the BT021's on the SV were out to kill me every time it got damp, so happy to have got rid of them!
kramdra
PostPosted: 01:44 - 20 Oct 2015    Post subject: Reply with quote
2 rears for a front is bollocks. Fronts have significantly less tread from new (4mm vs 6mm), and on a rear it matters far less. I run rears down to the cord, but all my crashes have had a front around 2mm. Therefore I now change early around 2mm, not that much above legal.. rears have 3x more usable tread.
I went back to PR2's, quite happy. I imagine being harder than PR3, its not soo much different to a PR4 at half price Laughing But brand loyalty is a stupid thing. Plan to try pirelli angel's next.
PostPosted: 05:47 - 20 Oct 2015    Post subject: Reply with quote
Of course it's bollocks, that's why 10 years FWR tyres ran a 'pack of three' deal for 2 rears and a front with the reason that this is the ratio most tyres wear at.
https://web.archive.org/web/20070820092530/https://www.fwr.co.uk/
mentalboy
PostPosted: 06:49 - 20 Oct 2015    Post subject: Reply with quote
I agree with this, although it probably depends on the type of bike you have.
I always managed a two to one ratio until I got the Zed and, like yourself, run rears to the cord (expensive otherwise, innit? Wink ). I tried two to one when I first got her but she handled like a shit pig, by the time the first rear was down to cord the front was scalloped to hell and the front end used to vibrate like a bitch.
I don't know if it's because the Zed was a heavier beast but suspect that it was more to do with the ever softer outer edges on 2CT type tyres.
Serendipity
PostPosted: 09:52 - 20 Oct 2015    Post subject: Reply with quote
My PR4s will be up for replacement very soon. They’ve done just over 10,000 miles and still technically legal, although the centre of the rear is getting close. That’s pretty consistent with the experience I had with the 3 pairs of PR3s I had on the bike before these. They all managed similar mileage and could have done more if I wasn’t reluctant about touching cloth. Wink
I’m finding that the front wear is making the bike a little squirrelly over white lines so I’ll be changing them as a pair in the next few weeks.
In my experience the CBF1000 has worn front and rear at the same rate. That could be down to the type of bike, weight distribution etc, but equally I think tyre design has changed over the years to make the fronts a little softer. I’d rather a bit of a spin up from the rear than having the front wash out. 10 or 15 years ago I was regularly doing 2 rears to every front, but looking back those tyres were a load of old gash compared to these current sports touring ones. I remember slipping and sliding all over the place on the likes of Bridgestone BT202s then suffering appalling handling as they became squared off. Chalk and cheese compared to the modern stuff.
When I fitted the PR4s I actually didn’t like them as much as the PR3s. I had a lot of trust in the 3s and it took me a while to come up to that level of trust in the 4s. I felt the 4s were a little more flighty and quick steering compared to the assured turn in of the 3s. However the grip has been plentiful and the rear has worn without squaring despite being hammered with motorway miles.
I’d be interested in trying something like the Dunlop Roadsmart family, but I expect I’ll go with the Pilot Roads again. They’ve been excellent so “if it ain’t broke don’t fix it”.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
blueglue
PostPosted: 10:03 - 20 Oct 2015    Post subject: Reply with quote
im another sucker for PR4's
Ive still got 1k left on my Dunlops (dead after 2.5k) but will go onto PR4's straight after.
I get mine from tyreleader.co.uk
PostPosted: 14:20 - 20 Oct 2015    Post subject: Reply with quote
FWIW I used the RoadsmartII last year and they were also a great tyre but wore a little quicker than the PR2.
Pigeon
PostPosted: 18:36 - 20 Oct 2015    Post subject: Reply with quote
I'm in the same boat. Loved the PR4's so fitted them to two bikes. But want to try the Roadsmarts next on one.
chickenstrip
PostPosted: 19:40 - 20 Oct 2015    Post subject: Reply with quote
Depends on usage. In winter, I'll get through more rear than front, but in summer, about the same on each. I also think that it may have changed over the years with tyre development, as the old rule used to be 2 fronts to one rear, and I seem to remember that being not far off the case. Doesn't seem to be so much so with the PR2s I still run, even in winter though.
Don't know about PR4s, not made the switch yet - no reason to, as I can ride in wet conditions with very little change to the way I do in dry on the 2s, very confident in them. But I also think it is one of those things where it also depends on the bike, the riding style and other factors. Not everyone likes the same tyres, even where the bike is the same.
PostPosted: 20:31 - 20 Oct 2015    Post subject: Reply with quote
I've long been a user of Battlax/BT02* tyres and they have always worn 2 rear to 1 front, but that's always been commuting in town and on commuter bikes. The BMW is far superior to my Bandit in the handling stakes so I tend to be heavier on the front.
Anyway, Pilot Road 4's are fitted to my wheels, collecting them tomorrow Thumbs Up
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 141.8 Kb
