| old-git |
 old-git Nova Slayer
 Posted: 16:24 - 09 Feb 2005 Post subject: front sprocket increase |
hi , i have just put a larger front cog on the front .was 15 now 16 .
but it doesnt seem to be very different ,
do you think it would be worth trying two extra teeth , or is that going to far ?  ____________________ live long and prosper .  |
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 16:47 - 09 Feb 2005 Post subject: |
Here's Renthals explanation of what to do;
But what does that mean about gearing...
The stock gearing of your bike is likely to have been determined by choosing a compromise ratio based on what worked best for test riders in "average" conditions. As soon as the bike is taken out of average conditions - by engine tune, terrain, track design or rider style the stock gearing might no longer be the optimum solution - a different setup might get you round the track faster.
Maximum speed occurs when the driving force is exactly counterbalanced by the air and rolling resistances. At this point the acceleration has fallen to zero.
Setting up the gearing of any vehicle is a trade-off between acceleration and top speed.
Gearing a bike up to produce higher top speed with less acceleration is done using a larger countershaft (gearbox) sprocket or a smaller rear sprocket.
Gearing a bike down giving it more acceleration with lower top speed is done using a smaller countershaft (gearbox) sprocket or a larger rear sprocket.
The ratio chart shows the gearing ratios for different numbers of teeth on the gearbox and rear sprockets. The numbers given are the number of revolutions of the gearbox sprocket required to cause one complete revolution of the back wheel. These figures are calculated by dividing the number of teeth on the rear chainwheel by the number of teeth on the gearbox sprocket.
From the table it is clear that changing one tooth on the gearbox sprocket has a significantly larger effect on the gearing than changing one tooth on the rear sprocket. To make a small change in gearing it is therefore necessary to change the rear chainwheel size by one tooth, as changing the gearbox sprocket makes a far larger difference in gearing.
Renthal Motorcycle Final Drive Ratios Chart; https://www.renthal.com/site/resources/ratios.htm |
| Scotsman37 |
| old-git |
 old-git Nova Slayer
 Posted: 16:57 - 09 Feb 2005 Post subject: |
Thanks for that.  ____________________ live long and prosper .  |
| G |
 G The Voice of Reason
| old-git |
 old-git Nova Slayer
 Posted: 17:03 - 09 Feb 2005 Post subject: |
yeh top speed of my bike is 60mph and then it is screaming .
i haven't tried it flat out since the sprocket change .
but it seems more or less the same around town .
i think i would have to change the rear sprocket for anymore gear ratio's as there is not much room for a bigger cog at the front  ____________________ live long and prosper .  |
| old-git |
 old-git Nova Slayer
| Scotsman37 |
| G |
| old-git |
 old-git Nova Slayer
 Posted: 17:46 - 09 Feb 2005 Post subject: |
many thanks ,that is just the info that i needed ..
i think i could go a couple of teeth less on the rear and that would do .
my bike is one of those that when you are in top gear ,you feel like you need to change up another one if you see what i mean.
thanks chaps .
.this is a quality forum  ____________________ live long and prosper .  |
| G |
| DM |
 DM Scooby Slapper
The last post was made 21 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
