Annoying vibe at 70mph
jjdugen
PostPosted: 23:26 - 21 Oct 2015    Post subject: Annoying vibe at 70mph Reply with quote
Bit long....sorry!
CBR 900 RR 1997.
I've been fighting this one for months. Rides fine until I hit approx 70 per. Then an odd vibe starts up, felt mostly in the L/H footrest, at first.
It is most noticeable on a steady state throttle, bimbling along in motorway traffic. The odd thing is that it changes with suspension flex, a sort of yawing vibe in tune with the slight suspension movement.
I have.....
Changed all back wheel bearings, non showing any wear. Changed chain and sprockets, DID and Talon, adjusted the chain through tight to slack, checked all engine mount bolts, all tight.
I did suspect that the chain might be rattling on the swing arm rubber, but that is smooth and shows no wear point. There is nothing in the front sprocket cover causing interference, I took that off to eliminate.
My thoughts are turning to the output shaft bearing, but would have thought this would grumble at all speeds. (It has no play that I can feel).
Anyone have a gearbox output bearing fail and what were the symptoms?
groovylee
PostPosted: 05:56 - 22 Oct 2015    Post subject: Reply with quote
have you checked the wheel balance?
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
jjdugen
PostPosted: 09:24 - 22 Oct 2015    Post subject: Reply with quote
Forgot about fitting the new tyre, balanced and then re-checked.
This is not tyre balance, I know that well enough. This is a tingly, grating, annoying vibe. BTW.... Its only at this speed and under these conditions, its fine at... higher speeds, (on a private road, of course), right through to 130 plus.
The output bearing is a complete engine strip so I need to know before diving in, especially as the motor runs perfectly in all other respects.
PostPosted: 10:47 - 22 Oct 2015    Post subject: Reply with quote
does it feel different depending on what gear you are in?
PostPosted: 13:03 - 22 Oct 2015    Post subject: Reply with quote
Vibration is such a difficult thing to pin point.
If it does happen at 70 only, yes, it could be the output shaft bearing. How about the front wheel bearings first, a much easier and cheap fix and if it doesn't cure it you haven't lost too much.
Can you remove the chain and front sprocket and see if there is any roughness/movement in the output shaft bearing?
jjdugen
PostPosted: 13:29 - 22 Oct 2015    Post subject: Reply with quote
I'll answer your points in order.
Any gear, 4th 5th 6th as long as its a steady state throttle at 70mph.
Front wheel bearings checked, smooth as silk.
I have hoisted its back end up and run it, problem is, there is no load to replicate the conditions and the chain thrash makes hearing anything untoward impossible.
I've looked carefully at all metalwork in any proximity for bright spots that might be interference, but all seems well.
Thankfully its nearing winter as it looks like an engine strip. Can't say I'm looking forward to it, might be the parting of the ways for my old girl and me!
The last post was made 11 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 53.49 Kb
