| Polarbear |
 Polarbear Super Spammer
| uberkron |
 uberkron Crazy Courier
| jimspeed |
 jimspeed World Chat Champion
| Polarbear |
 Posted: 12:24 - 23 Oct 2015 Post subject: |
Why? My present one is manual and I'm pissed off with it. What's your reasoning? ____________________ Victory Cross Country American tractor. |
 Posted: 15:32 - 23 Oct 2015 Post subject: |
| Polarbear wrote: |
Why? My present one is manual and I'm pissed off with it. What's your reasoning? |
I thought you were meaning you had some sort of oddball mechanical lift pump running off the engine mechanism.
Cheapo electrical stuff doesn't last well on boats before it becomes corroded and knackered in my experience.
Every boat we've had has used one of those squeezy-bulb inline fuel pumps which has worked well. I seem to recall having something similar to manually prime one of the diesel pickups we used to use if someone ran it out of diesel.
I suppose a lot will depend on how far it's being lifted as to how much effort it requires though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Polarbear |
| jimspeed |
| Stalk |
 Stalk Brolly Dolly
| WD Forte |
 WD Forte World Chat Champion
| Polarbear |
| MCN |
 MCN Super Spammer
 Posted: 00:25 - 24 Oct 2015 Post subject: |
I've seen those electric pumps doodahs on remote engines for tower-lights and bore-hole, air compressor, water pump engines and etc.. They seem to do the job BUT..... I would buy two as when they fuck up they are fishing weights. You cannot open them to repair.
They are somewhat reliable but I wouldn't go to sea relying on one.
I suppose on a Canal you can aye just phone a taxi though.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| WD Forte |
| MCN |
 MCN Super Spammer
 Posted: 16:02 - 25 Oct 2015 Post subject: |
Those pumps don't move a lot of fuel for 'the effort exerted'. Perkins use them and they were always a cnut to have to rely on for priming an empty system. They only move about 1-2cc of fuel. The problem is that the design is an attempt at making a dual purpose pump. As a lift/transfer pump and and as a priming pump.
I would keep the original arrangement (as fitted) but as suggested, overhaul the original unit using the kit (above).
The kits work and help increase the pump efficiency, if it's an ancient unit.
Nothing to stop you fitting the leccy pump and tee it in as a priming pump to save your wee fingers when servicing the fuel system.
Priming with those cam driven lift pumps is/are a cnut even when they are brand new.
Not sure if you have read it but priming needs to follow a sequence.
1) Prime until fuel issues from Tank to Outlet side of lift pump.
2) Prime until fuel issues from Outlet of lift pump to main filter housing.
3) Prime until fuel issues from Outlet of main filter. (Normally there is a plug or cock on top of the filter housing for that.)
4) Prime until fuel issues from the small (bastart size) bolt/plug in the side of the injection pump housing. The thread has a groove milled into the first few threads to let air and fuel weep out when slacked off a few turns. (But you normally end up removing the plug completely in one's frustration.)
5) Slacken the nuts of the injector lines at the injectors and prime until fuel issues from the lines. They recommend only one line needs to be opened but again in frustration all line will end up being opened.
If there is an electric ignition (Fuel Shut Off) control make sure this is on when you get to step 3. There is a solenoid valve in the pump housing to control fuel flow to the injection pump. Switching off the key/off switch will kill the engine. Some pumps use a cable shut-off or another solenoid to do the same as a cable will do. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Polarbear |
 Posted: 20:34 - 25 Oct 2015 Post subject: |
I know perfectly well how to prime a diesel system, especially this system thanks.
I am just thinking about making my life easier. How many diesels now use a mechanical lift pump? I doubt any, they all use electric so logically, fitting an electric pump should be an upgrade.
It might even make my engine go faster like fitting a pink powerband to a stroker.  ____________________ Victory Cross Country American tractor. |
| WD Forte |
| MCN |
 MCN Super Spammer
| Polarbear |
 Posted: 13:55 - 26 Oct 2015 Post subject: |
I've done it in 3 days from MK to Uxbridge
Point taken about cheap shit though. I'm going to spend a bit more on a decent one and fit that.  ____________________ Victory Cross Country American tractor. |
The last post was made 11 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
