valve clearance do i need to adjust after upgraded piston ?
adam1471
PostPosted: 19:42 - 23 Oct 2015    Post subject: valve clearance do i need to adjust after upgraded piston ? Reply with quote
yamaha ybr 125 . just upgraded the piston to a 150 kit do i need to adjust valve clearance or any thing else i need to adjust?
PostPosted: 19:53 - 23 Oct 2015    Post subject: Reply with quote
Yes you need to upgrade your driving license.
As far as the engine goes - since the YBR is overhead camshaft it's not likely that the valve clearances have changed but it's such an easy job to do especially with the engine out of the frame it really doesn't make sense to not check them at least.
Ariel Badger
PostPosted: 19:54 - 23 Oct 2015    Post subject: Reply with quote
It is OHC so the clearances will not have changed.
adam1471
PostPosted: 20:05 - 23 Oct 2015    Post subject: Reply with quote
its just iv rebuilt it and timing back and all it seems to do is backfire even with the cam chain ofset by a tooth ether way of the mark ? just cant seem to get it to start
Ariel Badger
PostPosted: 22:13 - 23 Oct 2015    Post subject: Reply with quote
Has your attempts at getting the timing right caused your piston to kiss a valve and bend it?
Ichy
PostPosted: 08:45 - 24 Oct 2015    Post subject: Reply with quote
I'd do a compression check first to make sure there are no leaks.
Have you checked the piston position in relation to the the cam timing? Has the piston changed the compression?
Have you tried starting it with something like easy start?
Teflon-Mike
tl;dr
PostPosted: 13:31 - 24 Oct 2015    Post subject: Reply with quote
Hmmm....
I like to start with the 'dumb' questions to start with; every time I think "Surely NO-ONE can be that daft!" all too often, I'm proved wrong.. the can, and more.
'upgraded piston to 150cc'..... that would sort of suggest, fitting one that's about 5% bigger in diameter than 'stock'; stock I'd imagine to be about 56mm, so, the 'big-bore' piston would probably be about 58mm-ish... which OUGHT not fit in the standard engine.. the cylinder would have to be made bigger, or replaced with a bigger one, to accept it..
Which begs the 'dumb' question, you DIDN'T just buy a bigger piston, and try sticking it in your engine did you?
'Cos more usually some-one would say, "I have fitted a 'Big-Bore-Kit' or say "I have re-bored the engine to 150cc" rather than 'fitted a bigger piston"
Opens a whole can of worms, like did you fit piston rings? Big-bore piston without rings would possibly fit in a standard bore.. just wouldn't seal very well...or possibly a tad too well, depending on the clearances!
As to the 'symptom' it not starting and back-firing... lots of other stupid stuff would beg investigation long before I started thinking it may be somethg to do with the piston...
Why did youneed/want to fit a new piston? Was the engine buggered before hand? If so, new piston NOT 'fixing' the buggered engine.. WAS the piston the problem?
Have you got a mashed valve? Broken rocker, fucked cam? Was the cylinder head gasket knackered.. THEN.. when you fitted ew piston, you DID use a new head-gasket, didn't you... you DID, PLEASE say you used a new head gasket!
What about exhaust gaskets? Carb gaskets? Did you pinch the carb rubber? IS the carb-clamp actually done up?
Have you fitted the carb slide the right way round? What about the plate in the slide that presses the main-jet needle down.... that is seating, isn't it? Needles not flapping up and down i the jet, or dropped i it, cos the c-clp got pinged?
Were the spark-plug threads stripped in the head at some point? Has it got a new plug? When you put the new piston in, did you use a light lube on the piston rings for first 'start'... has that il burned off yet, fouling the plugs?
The list of dumb questions is very very log and tortuous.. like my posts... and most of them are 'just' common sense... and starting over, at the beginning, and working through the list of easy and obvious, towards the involved and obscure, eliminating possibilities in a logical manner, rather than stabbing wildly in the dark, making guesses and presumptions....
which is all we can do adding to the Brownian motion, random notion generator, as WE don't know the story behind this here engine, or have it in-front of us to poke and prod and swear at.. that be your job!
PostPosted: 13:34 - 24 Oct 2015    Post subject: Reply with quote
for the benefit of tef tl:dr people, tell us what you ACTUALLY did to the bike, what parts you changed and the process to ensure the cam timing is correct.
Teflon-Mike
tl;dr
PostPosted: 13:59 - 24 Oct 2015    Post subject: Reply with quote
NOT necessarily.... if he has fitted a big-bore kit, then 'yes'.. he would also have to declare the capacity change to DVLA so they can charge him the higher tax rate.. or that would be the even greater potential penalty of 'tax evasion'.
However, IF the cylinder has been re-bored, and within manufacturers specified service limits, then according to the legal reqs, its 'still' a 125 as originally 'registered', would you believe?
Same applies / applied to 'Production' bikes in race regs, and a couple of manufacturers exploited it back in the late '70's, re-writing the service manual to extend the over-bore limits, so that 350's could be 'blue-print' built with 375cc barels; Pretty sure there was a 550, that could be blue-printed out bigger than the 750 above it in the catalogue! Cant remember which one though... probably a Honda, the SOHC 750 'Fours' had a peculiarly small bore and long stroke.
Anyway, Honda still offer over-size pistons on the small-bore motors in 1/4mm increments, up to seven over-sizes or so.
On the 125 Benlye engine, takes it from 125cc on a (2x) 43x41 BxS up to 142c at 44.5 x 41. Conveniently the dimensions of the Asian Market CB/CM/CD150.. so IF you 're-bore' your original cylinder and fit over-size pistons.. its still legal as a 125, its not deemed a mod, 'cos its in manufacturers service limits... but if you buy a Chinky '150 Big-Bore' kit (replacement parts for the 150 models for which there are no 'over-sizes' available), cos cheaper to buy new barrel than get one machined... THEN its deemed a 'modification' by the C&U regs, even though ends the same, and the bike's no longer 125cc and learner-legal.
On the CG singles, the 7 over-sizes are magnified by the longer stroke, and I think that at max over-bore they are something closer to 160cc where the twins are only 140....
NOT that it makes bog-all odds, in real terms to the power the things don't make, sucking through the same tiny valves.. but still, academically interesting.
PostPosted: 18:13 - 24 Oct 2015    Post subject: Reply with quote
No 'ifs' involved Teflong. In the opening paragraph he says he's fitted a 150cc kit.
The last post was made 11 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 72.65 Kb
