re-fitting ZR600 air box & carb drain screws
Wonko The Sane
PostPosted: 20:10 - 23 Oct 2015    Post subject: re-fitting ZR600 air box & carb drain screws Reply with quote
Need to replace the air filter, spark plugs and also drain the carbs this weekend.
When I fitted my restrictors it took me about 2 days to get the air box back on as the ram air pipes come in on two sides of the triangular end - I'm guessing there's a technique to it?
anyone care to share?
With draining the carbs, where is the drain screw, is it somewhere obvious?
ta
Amber Phoenix
PostPosted: 11:01 - 24 Oct 2015    Post subject: Reply with quote
It's a faff, yes . Best plan is to remove some of the right hand fairing/infils so you can access the right ram air pipe from other side of frame. Slot left in, put air box in place then shove right pipe in. A lot of pushing, shoving and bends of pipes will still be in order though.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
wr6133
PostPosted: 12:03 - 24 Oct 2015    Post subject: Reply with quote
Drain screw is on the bottom of the carbs. Ram air no idea my older version doesn't have.
The last post was made 11 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 35.42 Kb
