lexmoto street no electrics at all
antuk
PostPosted: 14:34 - 25 Oct 2015    Post subject: lexmoto street no electrics at all Reply with quote
Hi can anyone help me please. Lexmoto street 125 .its dead as a dodo no electrics what so ever no lights no horn nil.battery is fine .pulling hair out.I've tried swearing and been nice to it as well.plz help.
RhynoCZ
PostPosted: 16:17 - 25 Oct 2015    Post subject: Reply with quote
Find the main fuse, it should be on the + wire that goes from the battery to the starter relay. On many motorcycles the main fuse (30A mostly) is mounted in the starter relay housing. If that fuse goes, it's like the battery was not connected to the motorcycle at all. Thumbs Up
That if the ignition barrel is alright and working (the ON key position).
This thing (the main fuse should be in the housing of it, or very near the relay):
https://i.ebayimg.com/00/s/NDk5WDUwNA==/z/0iQAAOxygPtSwCQe/$_35.JPG
antuk
PostPosted: 16:23 - 25 Oct 2015    Post subject: Reply with quote
Checked fuse.even bypassed it to check.I get no horn no lights no clicking, turn ignition on not even ignition light.
RhynoCZ
PostPosted: 16:27 - 25 Oct 2015    Post subject: Reply with quote
Have you checked the wiring to the ignition barrel? Any damage of the wiring near the neck could cause this.
EDIT: I've never worked on a Lexmoto, but according to prices those are being sold for, I'd imagine poor wiring quality. Or if someone already fiddled with the wires around the neck, the routing could be wrong and the steering is killing the wires now.
EDIT II: Just out of my curiosity, are you sure there's no excessive oxidation on the battery's terminals? Also check all the ground points (it is not common thing, but I guess it could also be the culprit).
antuk
PostPosted: 16:47 - 25 Oct 2015    Post subject: Reply with quote
I've took the tank off.and checked all the wires the battery terminals are clean and battery fully charged. Checked earths .I'm thinking two parts could be at fault 1st stator solenoid 2nd ignition barrel.where ever I've seen any wires iv checked with amp meter .it will turn over if I cross the terminals on the stator solenoid with a spanner.
RhynoCZ
PostPosted: 19:11 - 25 Oct 2015    Post subject: Reply with quote
It must be the ignition barrel then. Unplug it, clean the contacts, plug it back in. That might help. There should be a 4 (or more) wires socket and plug. Nothing complicated, can not be plugged in the wrong way. Thumbs Up
antuk
PostPosted: 14:41 - 26 Oct 2015    Post subject: Reply with quote
Its dead even at the ignition barrel.
PostPosted: 15:19 - 26 Oct 2015    Post subject: Reply with quote
Sorry, no insights other than to say that you've got a good earth since the starter is spinning, so it's time to do continuity checks on the wiring between the battery and the barrel.
Electrics make me Sad
RhynoCZ
PostPosted: 16:26 - 26 Oct 2015    Post subject: Reply with quote
Well, if you can't even bypass the ignition barrel, then something just must be fecked up. Was it even working before? Thinking
antuk
PostPosted: 16:45 - 26 Oct 2015    Post subject: Reply with quote
Yesssss found the fault.+wire from battery move it no power move it again power Laughing now to get back lights to come on and low beam.wahoo must be a simple plug I have knocked trying to find original fault.can't believe it was a simple wire cracked. Thanks to all that helped.
RhynoCZ
PostPosted: 16:46 - 26 Oct 2015    Post subject: Reply with quote
https://36.media.tumblr.com/tumblr_m7bjr0xDHj1rbsctpo1_500.jpg
The last post was made 11 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 15 - Page Size: 68.27 Kb
