rieju rs3 125 steering fault
dids212
PostPosted: 02:36 - 25 Oct 2015    Post subject: rieju rs3 125 steering fault Reply with quote
Hope some one can help ive recently past my cbt and ive bought a rieju rs3 125 on a 13 plate ive only been riding it for a few hour when the steering started turning to the left. I now nothing about the mechanics of the motorbike and it shook me up a bit can any body advice me on this thanks for any help
Nexus Icon
PostPosted: 09:28 - 25 Oct 2015    Post subject: Reply with quote
First thing to check is tyre pressure. It's also the one thing most likely to change over the course of a few hours.
Can you expand a bit on the symptoms too? Speed you're travelling, whether the bars are aggressively turning to the left at low speed or if the bike is just wandering to the left at normal road speeds.. That sort of thing.
Greetings from Shitsville!
PostPosted: 09:39 - 25 Oct 2015    Post subject: Re: rieju rs3 125 steering fault Reply with quote
Assuming that you mean that literally (good job for not posting from A&E), are the forks square in the yokes, and are the fork clamps secure? Have you checked the frame and headstock for damage?
dids212
PostPosted: 21:21 - 25 Oct 2015    Post subject: Reply with quote
That was the first thing a thought of was the Tyre pressure but the seem fine the rock solid and it a was traveling about 30 mph. The bars never suddenly turned to the left they just gradually started to veering to the left. after it happened i just rode home shitting my self lol lol and put it in the shed and its been there since. Im going to get it out tomorrow and have a look at it see if there anything obvious up with it not that a now what am looking at or anything a mate said he will have a look at it for me.
Nexus Icon
PostPosted: 22:01 - 25 Oct 2015    Post subject: Reply with quote
Give everything on the front end a good bounce, shake and twist. See if anything moves that shouldn't. Also check the rear tyre pressure.
What's weird is that things don't usually just 'go' like that. Bearings wear, frames get bent, forks twist, sure, but bearings will grumble and get notchy first, usually, and you'd know if you'd had the sort of incident that leads to bent metal.
The wheels may be slightly out of alignment, you can check that with a length of string (there are YouTube vids that help) but is there any chance you were just on a horribly cambered road surface at the time the issue arose? 125 tyres, especially the horrible hard compounds they tend to fit at the factory nowadays, can track quite significantly on bad roads.
RhynoCZ
Isn't it possible, you just went across a longitudinal unevenness on the road? Sometimes lorries and other heavy vehicles in general imprint straight lines (rails) into the tar, which affects cars and esp. motorcycles. It forces the wheels of the bike to get inside or outside the line (rail). The most deep lines (rails) tend to be in the intersections with traffic lights, as when in summer the heat gets up, the tar gets more soft/formable and standing vehicles have more time to feck up the road.
Stuff like this:
https://www.consultest.cz/wp-content/uploads/2013/07/6-vyjete-koleje.png
dids212
PostPosted: 00:19 - 26 Oct 2015    Post subject: Reply with quote
No it deferentially wasn't the road because it started veering to the right a little on the way home. and its weird when a take a roundabout it sort of pulls out a bit as if it cant get round if you no what a mean. i just put it down to bad handling an just getting used to the bike at first till that happend on the road.
RhynoCZ
PostPosted: 00:26 - 26 Oct 2015    Post subject: Reply with quote
Check the brakes are not dragging. When I had issues with the Tokico 6 pots, some of the pots were returning a bit slower than the rest, causing it randomly dragging, which felt like a force pulling me out off the corner. Which is what happens when you apply the front brake mid corner, the bike has tendency to straighten up. Thinking
The last post was made 11 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 55.97 Kb
