Tyre fitting machines
Gazz
PostPosted: 21:09 - 26 Oct 2015    Post subject: Tyre fitting machines Reply with quote
Does anyone know if tyre fitting machines are the same for cars as they are for bikes?
And if so, why does the places around here which usually do cars not do bikes as well?
BakesBeans
PostPosted: 21:19 - 26 Oct 2015    Post subject: Re: Tyre fitting machines Reply with quote
My mates a tyre fitter, he says he can fit the tyre but can't balance it. Not sure why..
Not that this information helps in any way.
Current: Kawasaki ZX636
Previous Bike: Honda CBR600F ABS, Yamaha XJ6 F Diversion ABS, Honda VFR400 NC30
MCN
PostPosted: 21:24 - 26 Oct 2015    Post subject: Reply with quote
The wheel centers on cars are bigger/different design than on bikes.
Bike wheels need a special adaptor so the bike wheel can be mounted on the arbor of the balancer.
And.. some car tyre fitters are not interested in any liability with bike wheels. Jus wot ahv'e been told by car tyre places
iooi
PostPosted: 21:42 - 26 Oct 2015    Post subject: Re: Tyre fitting machines Reply with quote
Well a car just needs to be jacked up and a air gun to release wheel nuts to change a wheel... Which any monkey can do (well sometimes) Embarassed
Now take a look at your bike..... Not quite as easy is it. Especially if you only have a side stand.
I would not trust your average tyre fitting place to do my bike. Which is why it goes to the local-ish place that deals with bikes to do my ride in ride out jobs Thumbs Up
monkeybiker
PostPosted: 22:33 - 26 Oct 2015    Post subject: Re: Tyre fitting machines Reply with quote
I agree, that is probably the reason.
binge
Emo Kiddy
PostPosted: 22:44 - 26 Oct 2015    Post subject: Reply with quote
This is the machines we have in the workshop.
They are one of the best on the market. Typically a car tyre changer.
https://www.changemytyre.com/Upload/fldProducts/201312300950542914-Tyre-changer.PNG
This is a typical bike tyre changer:
https://www.corghi.lv/corghi/BC200Sl.png
Strictly speaking, you can do either type, on both machines.
But there are certain limitations of both, for certain types of car/bike wheel/tyre.
The bike changer wouldn't stand a cat in hell's chance of changing a big 20" runflat car tyre.
Likewise, the car changer wouldn't manage some front bike wheels, or smaller scooter wheels.
Reason being, the bike changer wont be gutsy enough to do the heavy duty car jobs.
And the car changer top arm does not come down as close to the jaws as on a bike changer, making any bike rim narrower than about 4j, quite difficult to do.
Notice the jaws on the bike changer stand quite a big higher. This allows the narrow 1.75" MX rims and similar to fit.
HTH.
MCN
PostPosted: 22:45 - 26 Oct 2015    Post subject: Re: Tyre fitting machines Reply with quote
They can 'fit' a bike tyre using a 'car' tyre machine jsut as easy as a car tyre. It's the balancing that is 'unusual'. ANd as said whipping the wheels off and on is a bit more involved. Bike shops charge to remove wheels fit and balance tyre/s and refit.
binge
Emo Kiddy
PostPosted: 22:57 - 26 Oct 2015    Post subject: Re: Tyre fitting machines Reply with quote
Not many bike fitting shops run dynamic bike balancers. Most just use the old fashioned static balancer units, which is essentially a couple of axle stands and a bar. The fancier ones have their own integrated bearings for finer balancing.
kramdra
PostPosted: 23:07 - 26 Oct 2015    Post subject: Re: Tyre fitting machines Reply with quote
The professional monkeys in many places have not got a clue and can only do things as they have been shown. You dont need a changer machine or compressor to fit tyres.. you can balance a wheel quite well with it in bike and brake calliper removed.
You dont need to pay 5 quid extra for a 20p valve and balancing Mad valves are cheap enough to replace every time.
Secondly refitting a bike wheel requires some care, rather than just blasting nuts with impact gun. Its a very easy job to do yourself, and much less risk of fuckups than expecting a car place to do it properly. I can do a tire as quick as ride to garage Thumbs Up
Bike shops are not much better.. dealerships very good at fucking up.
Kaya75
PostPosted: 14:27 - 27 Oct 2015    Post subject: Reply with quote
Where ab
outs are you ? I asked around and found a great bike tyre place in Romford , Harold wood road. It's worth a ride out to a decent place, plus you run them in on the way home Thumbs Up
MCN
PostPosted: 15:25 - 27 Oct 2015    Post subject: Reply with quote
Removing and fitting bike wheels is not 'easy'.
There are certain ways to do it and it can take a bit of knowledge to do it properly.
The bike is very stable on its wheels and side stand but very unstable if a wheel is removed.
To do it safely you need paddock stands or something similar (ABBA stand etc.).
You need to observe which way the tyres/wheels are fitted as they are very 'directional'.
You need to pay attention to the parts used to hold the wheels in place and also the adjustment of the rear wheel.
There are many more points to consider. It is not 'simple' but is is very do-able if you are determined and keen enough. If you do not have space to do the work then you are stuffed and have to pay the garage.
Taught2BCauti...
PostPosted: 15:50 - 27 Oct 2015    Post subject: Reply with quote
There are several independent tyre fitters near me, and all but one will do bike tyres as long as you remove the wheel yourself and bring it in.
One of them will even collect and deliver for a small additional charge.
The one that doesn't do bikes, has a really old machine that has a central boss that is too big to take a bike wheel. Most modern machines don't have this, and will accept bike wheels - but the management might decide not to do your bike if they think their machine might damage the rim.
None of them do balancing for bike wheels, because the balancing machine also has a central boss that is too big to take a bike wheel.
None of them stock bike tyres either, but will supply to order or fit yours.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Mudshark
PostPosted: 15:54 - 27 Oct 2015    Post subject: Reply with quote
depends on the bike, back wheel in particular on mine is a piece of piddle to remove and replace.
https://i1255.photobucket.com/albums/hh637/dave_thom1/2015-05-12%2018.52.08_zpsekhxr3mm.jpg
R1250RS
XT660X
MCN
PostPosted: 20:31 - 27 Oct 2015    Post subject: Reply with quote
Aye OK.
I have a bike with a single swing arm and a bike with a double swing arm. But when discussing 'removing bike wheels' the difficulty is with double swing arm and front wheels.
So I'm still right. Razz
Very Happy
Edit: I've taken the operchancity and cloned your plate. Thumbs Up
Fladdem
PostPosted: 20:58 - 27 Oct 2015    Post subject: Reply with quote
I use the car tyre machine at work for my bike tyres. The issue is the really skinny tyres, like the 90/90/21's on my 250's. the machine can't adjust to that so I just use the machine to hold the wheel then use tyre levers. Thumbs Up
I can't balance it using the machine, but I belive you can balance it by fitting it back on the bike, spin the wheel, let it stop somewhere, mark the point it stopped, spin again, if it stops in the same place, that means it's heavier there, so directly opposite stick a weight. Keep doing so until it doesn't stop in the same place twice. I think it's something like that anyway. Confused
The last post was made 11 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 90.79 Kb
