Air cut off valve (CG125)
CG125
PostPosted: 16:26 - 27 Oct 2015    Post subject: Air cut off valve (CG125) Reply with quote
I have a Honda CG125
Replaced carb 6 months ago with the one which had air cut off valve in it....and the popping on deceleration was gone.
Now the problem is back....currently it's not that severe..but still it's there.
Now i want to ask that is it possible that air cut off valve (diaphragm) might have become damaged.....as i once washed the carb with normal tap water....or due to some other reason ?
i have checked thoroughly and there are no leaks....what other issue can be there.....can it be due to over tightening of valves....why is the issue back so early ??
I have been using high octane for a couple of months....could it have some how damaged the engine as CG125's engine does not have that high compression.
Some help from fellow members would be really appreciated.
If you ride like there's no tomorrow there won't be
Ariel Badger
PostPosted: 17:33 - 27 Oct 2015    Post subject: Reply with quote
check for leaks to hoses and connections including your exhaust, strip the carb, inspect and clean, the only damage running high octane fuel will do is to your wallet.
RhynoCZ
PostPosted: 17:44 - 27 Oct 2015    Post subject: Reply with quote
High octane fuel is only beneficial in a engine that was designed to benefit from it. The number tells you how resistant the fuel is to ''self detonation'' in, mostly, high compression engines. Thumbs Up
So high octane fuel in an normal engine won't have any effect on performance nor harm it, but not vice versa. If you've got high compression engine, then low octane fuel will affect performance and may even harm the engine.
CG125
what about exhaust washel.....i removed the exhaust once and didn't replace it as it was almost new....
PostPosted: 18:12 - 27 Oct 2015    Post subject: Re: Air cut off valve (CG125) Reply with quote
Why?
What?
It's not helpful to assume that we know what you're talking about. What model, what carb, and how did you set it up and check the fuelling when you fitted it?
Are you running with a cone filter, funky jets or any other go-fasta gubbins?
Could be. It only takes half an hour to check the valves.
However, I would suspect the exhaust is sucking air. An exhaust crush washer is only supposed to seal once. I'd get it off and slam some assembly paste in there, see if that helps. If so, do it right, replace the crush washer.
One thing at a time, don't change everything and hope that something sorts it - you won't know what was wrong if it re-occurs.
CG125
PostPosted: 19:42 - 27 Oct 2015    Post subject: Re: Air cut off valve (CG125) Reply with quote
Rogerborg wrote:
Why?
It was popping like hell at that time....my mechanic began trouble shooting by changing parts (CDI unit, coil etc) and seeing if popping went away. In the end it came down to carb when he switched it with his own used carb it went away. He said "your carb is the problem". So i told him to replace it with new. And he did and the problem went away.
Rogerborg wrote:
What?
Sorry..... the cg's which came in Pakistan before 2012 had simple carb's with no air cut valves. God knows how they managed to prevent popping as air cut valves are specifically designed to counter it. Now 6 months ago when my carb was diagnosed to be at fault i had option to replace it with either the same or go with the latest (the one with ACV). Knowing what ACV was meant for i decide to go with latter. After that i have been getting superb mileage....but this cursed popping is back...it isn't that much at the moment.....but i am afraid it might increase.....and would effect my $40 carb again Sad
Nope it's bone stock and completely genuine. Here are its pics
https://goo.gl/photos/8BsvgczfyvhryZAE9
I say this because this problem seems to start after i had the last tuning done. Carb wasn't touched during tuning. Tappets were tightened via feeler gauge.
This seems to be the main culprit....actually i ended up breaking one of the tappet cover bolts inside so the head had to be disassembled for the rest of the bolt to be taken out. Obviously exhaust was also removed and i didn't replace the washel. However this took place about 2.5 months ago, so i doubt even this has something to do with it.
To be honest i don't want to replace anything......this thing has already cost me almost $950 and continues to give me headaches.
CG125
PostPosted: 07:13 - 02 Nov 2015    Post subject: Reply with quote
Anyone ???/ Sad
The last post was made 11 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 59.12 Kb
