carb settings
Keir
PostPosted: 22:21 - 27 Oct 2015    Post subject: carb settings Reply with quote
just bought a 50cc monkey bike, made by baotian. its a cheap Chinese thing but was cheap so everyones a winner.
except.... it runs great when using anything up to 3/4 throttle. after that it bogs down and pops/bangs. its quite usable as it it but would be nice to be able to go full throttle and see what the machine can do (very little probably)
Not sure if its rich or lean , give me some tips of how to sort this out. please.
Current : '08 Yamaha FZ1s
temeluchus
PostPosted: 22:25 - 27 Oct 2015    Post subject: Reply with quote
All hoses unkinked? Fuel tap flowing freely? Tank and carb not full of water? Airbox present and properly fitted?
RhynoCZ
PostPosted: 22:29 - 27 Oct 2015    Post subject: Reply with quote
You can smell rich mixture, if you are not familiar with the smell, check the spark plug:
RICH (running cold, distinctive smell, black spark plug)
- Clogged air filter
- Stuck choke
- Someone was ''smart'' and put a bigger jet there (why?)
LEAN (running hot, white insulator, probably damaged/baked)
- No air filter
- Missing the air box + fitted a pod filter that lets through way more air than it should
- Air leaks
- Someone was ''smart'' and put a smaller jet there (why?)
https://www.v6z24.com/mods/howto/images/plugs/plugs19.jpg
Keir
PostPosted: 00:34 - 29 Oct 2015    Post subject: Reply with quote
solved.
Having been sat for quite a few years the main jet was partially blocked. Had the carb out and plenty of carb cleaner later its running great.
runs right off the clocks now, but they do only go to 40mph!
RhynoCZ
PostPosted: 06:19 - 29 Oct 2015    Post subject: Reply with quote
Well, 40mph is 11.875mph faster than what an Am friendly bike should be. Wink
The last post was made 11 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 45.12 Kb
