Observation on Mod 2 - When mirrors and when shoulder check
chupacabra
PostPosted: 15:11 - 28 Oct 2015    Post subject: Observation on Mod 2 - When mirrors and when shoulder check Reply with quote
Hello All
In couple of days I have my Mod 2 exam and I’m not sure about couple of things.
One of them is when you should do the observation by checking mirrors, when by shoulder check and when both?
I’m a bit confused because I keep hearing different things from different sources (even from riding instructors!), regarding certain situations. For example:
1. When moving off from traffic lights
2. When moving to the side of your lane, before turning
3. When accelerating
Is there a general rule when to use each observation?
andyd87
PostPosted: 18:35 - 28 Oct 2015    Post subject: Reply with quote
I did my mod 2 a few weeks back and I was taught (and passed) on
mirrors at lights at maybe shoulder check if theres a bike lane or cars in lane next to you.
when moving to side of your lane to turn mirrors, indicator, and shoulder check just before moving over and again just before making the turn.
Just mirrors when accelerating from say a 40 to a nsl road.
I don't think you can do too many obs the examiner is looking for you to be safe on the road and aware of whats happening around you more than doing everything by the book (or at least thats how I found it) and if you think you might of missed one dont let it worry you too much I thought i'd failed mine early on doing 30 in a 20 but only got a minor for it as he said the rest of my riding was fine and I corrected my error pretty quickly.
Matt B
PostPosted: 18:51 - 28 Oct 2015    Post subject: Reply with quote
You will get many many different responses, each will be different so good luck working it out. Best off getting a definitive answer from your instructor who does this every day, rather than random internet bods who did a test once and now forgot it all Wink
As a rule of thumb mirrors are for changes in speed and lifesavers are for changing lane position.
chupacabra
PostPosted: 19:46 - 28 Oct 2015    Post subject: Reply with quote
Thanks for advice.
As far as I remember my instructor was saying:
When it comes to turning left; before you move to the left side of your lane you do the shoulder check first (not even mirrors) especially for to check for bicycles and other motorbikes, then once you are near the kerb, you don't have to do the shoulder check when moving off (if you are close to the kerb, than nothing will overtake you on the inside anyway).
When you turn right, again; shoulder check before moving to the right side of your lane and before you turn, another shoulder check, to be sure that no one is overtaking you.
But I'm not sure now, that's why I'm asking.
If you are going to do shoulder check is there a need to check mirrors at all? How reliable is checking mirrors? I remember instructor on my CBT course telling me that the mirrors are useless (blind spots) and you are better off if you remove them and only do the shoulder check, even when pulling off traffic lights.
Also what is correct order in OSM\PSL routine?
Mirrors, Shoulder check, Signal, Manoeuvre or
Mirrors, Signal, Shoulder check, Manoeuvre?
trevor saxe-coburg-gotha
PostPosted: 20:28 - 28 Oct 2015    Post subject: Reply with quote
You're drilling too far down into the minutiae of it there, in my view. So for instance, even if I were to say the latter is preferable, you could theoretically still do all that *and* cause danger to other road users or and/or pedestrians. Conversely you could do the former and complete a manoeuvre safely. So if that happened, the more correct one would result in a fail. Obviously.
I suppose what I'm trying to say is that a pass or fail won't be decided on whether you do it the former way or the second. In fact, in the heat of combat, you may well HAVE to do some strange combination. You have to *know* where you need to look, and not only that, but be able to demonstrate that you're looking there. So mirror checks have to be somewhat exaggerated. I digress.
I'm fairly sure I missed the odd obs on my mod 2, although none were mentioned. However I convinced the guy I was riding well. Whereas the first time I didn't. Because I wasn't. My second go was loads better. I think what I'm getting at is that it's far more than a check list.
roboff94
PostPosted: 22:00 - 28 Oct 2015    Post subject: Reply with quote
I did my mod 2 last week, and i made a note to check mirrors/shoulders when setting off from lights/stationary, moving across the lane, either to go around parked cars or pull in at the side of the road, at junctions and roundabouts, and everytime i went through a speedlimit change sign, as in going from a 60 to a 30 (or vice versa), check before you get to the sign.
To be honest i just used to check my shoulders rather than mirrors when setting off cause i think i was just moving my eyes rather than my head when doing mirrors, so it appeared as though i wasnt doing anything....
Thats what i was thinking through my test and i didnt get any faults for observations Very Happy good luck!
Marclev
PostPosted: 00:44 - 29 Oct 2015    Post subject: Reply with quote
Oh yes you can. If you keep on looking over your shoulder all the time, it seems to me you're more likely to end up doing something outrageously dangerous because you're spending less time looking in front of you. Never mind that you'll look completely unconfident and that will likely reflect in the rest of your riding as a result.
Marclev
PostPosted: 00:50 - 29 Oct 2015    Post subject: Re: Observation on Mod 2 - When mirrors and when shoulder ch Reply with quote
chupacabra wrote:
Hello All
Basically, check your mirrors every few seconds, but only when it's safe to briefly focus away from what's in front of you. Nowhere near as many shoulder necessary checks are necessary as you'd think from reading stuff on the internet, but the ones you really have to do are well .... "life savers", as they say. Only real way to know for sure though is to ask your instructor and listen to what he tells you.
The shoulder check is really a blind spot check, so basically you use your mirrors just to keep a general awareness of what's going on and only use the shoulder checks if you're about to perform a maneuver where there's a risk of crashing into someone in your blind spot (again, ask the instructor what these are), and use it as an escalation of the mirror check.
PostPosted: 01:19 - 29 Oct 2015    Post subject: Reply with quote
Keep it simple.
1. When moving off from traffic lights :
Left look right look. (lifesavers)
2. When moving to the side of your lane, before turning:
For turning, mirrors, signal, shoulder check, move over. For changing position, passing parked cars, cyclists etc, just a shoulder check before moving out, and before moving in.
3. When accelerating :
Any change of speed then check the mirrors. EG 30mph into a 40, check mirrors, get on the gas. 40MPH into a 30, mirrors and get off the gas.
PostPosted: 13:01 - 29 Oct 2015    Post subject: Reply with quote
What Matt and pinky said, I'll just chime in to remind you to ensure that your look-arounds are big and obvious. You're demonstrating that you're doing it, the examiner can't see through your eyes.
I deliberately say "look-arounds" rather than "shoulder check" or "lifesaver" because I think the distinction is specious and a bit spergy.
And don't fret, it's not a hard test and chances are that you'll pass it.
The last post was made 10 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 70.4 Kb
