Chinese 125
dcd1979
PostPosted: 15:47 - 28 Oct 2015    Post subject: Chinese 125 Reply with quote
Hi I have a Chinese vulcan 125 custom, I have recently changed the head due to a broken exhaust port and since putting it back together it seems to be rattling, I am unsure if it is the tappets as I can't seem to find the settings anywhere, any advice appreciated
Dave
PostPosted: 17:34 - 28 Oct 2015    Post subject: Reply with quote
Without googling, off the top of my head for generic clearances, tappets 0.2 inlet, 0.3 exhaust? Should do till you get the proper distances.
Ariel Badger
PostPosted: 17:48 - 28 Oct 2015    Post subject: Reply with quote
Is it OHC or pushrod?
PostPosted: 19:44 - 28 Oct 2015    Post subject: Reply with quote
It's the pushrod CG125 copyengine, so 0.08mm for both, or four three thousandths of an inch in old money.
dcd1979
PostPosted: 00:42 - 29 Oct 2015    Post subject: Reply with quote
That's what I thought and set them to
PostPosted: 09:30 - 29 Oct 2015    Post subject: Reply with quote
Wild thought, do the oilways match up perfectly and is the head getting lubricated? I wonder how long a pushrod head will run without lubrication. Thinking
dcd1979
PostPosted: 11:54 - 29 Oct 2015    Post subject: Reply with quote
Yes plenty of oil up top really confusing me
Robby
Dirty Old Man
PostPosted: 12:27 - 29 Oct 2015    Post subject: Reply with quote
If it's a metallic ticking noise, then the problem is likely to be the exhaust gasket. Doubly so if you didn't replace it when you changed the head.
dcd1979
PostPosted: 12:48 - 29 Oct 2015    Post subject: Reply with quote
It had new gaskets fitted
WD Forte
PostPosted: 00:30 - 30 Oct 2015    Post subject: Reply with quote
You did do them at TDC on the compression stroke and not the overlap stroke?
You wouldn't be the first to get that wrong if you did
bikers smell of wee
dcd1979
PostPosted: 11:26 - 30 Oct 2015    Post subject: Reply with quote
I think so but now I'm not sure what is the best way to make sure u r on compression stroke ?
WD Forte
PostPosted: 15:43 - 30 Oct 2015    Post subject: Reply with quote
Most bike have a TDC pointer but to ensure you're on the correct stroke
I'll watch the inlet rocker as I slowly turn the motor in its normal running direction with the plug out
and maybe ( carefully!) use something down the plug hole if I can't watch the piston.
When you see the inlet rocker move to open its valve and the piston moves downwards you're on the induction stroke.
When you see the rocker/valve close and piston starts upwards
that's the compression stroke so you then continue carefully until it reaches TDC.
there will usually be some corresponding marks on the flywheel to
help determine exact TDC.
bikers smell of wee
Ariel Badger
PostPosted: 20:52 - 30 Oct 2015    Post subject: Reply with quote
If you do poke things down your cylinder (and there is nothing wrong with doing so) make sure it is a pencil. My mate phoned me to say he had trapped a pencil with the piston and snapped it off and wanted to know what to do, I told him to just start it up. He did and other than a few sparks coming out of the pipe it did no harm.
The last post was made 11 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 74.43 Kb
