DTR 125 help
Dtr1251000
PostPosted: 18:42 - 28 Oct 2015    Post subject: DTR 125 help Reply with quote
Hello again people
Why would my neutral light stay on when in gear,
I haven't got a spark after replacing the stator and ignition coil I've disconnected the kill switch and side stand switch is grand any one have advice would be very much hope appreciated
Dan
Burnzy1989
PostPosted: 16:34 - 31 Oct 2015    Post subject: Re: DTR 125 help Reply with quote
Dtr1251000 wrote:
Hello again people
check your wiring and check your neutral light switch is not at fault , also join up the side stand switch wires and reconnect your kill switch and see if it makes any difference plus make sure all your connectors are in place and check your rectifier has not burnt out
Dtr1251000
PostPosted: 13:13 - 03 Nov 2015    Post subject: Re: DTR 125 help Reply with quote
[quote="Burnzy1989"]
Dtr1251000 wrote:
Hello again people
check your wiring and check your neutral light switch is not at fault , also join up the side stand switch wires and reconnect your kill switch and see if it makes any difference plus make sure all your connectors are in place and check your rectifier has not burnt out[/quote
From
Thank you for your time would a broken rectifier cause a no spark issue mate I think it's the cdi as everything has been replaced lol. Dan
Dan
The last post was made 11 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 35.38 Kb
