Motorcycle VFR 800 Caliper Mounting Boot Seal
Ottocle
PostPosted: 21:21 - 29 Oct 2015    Post subject: Motorcycle VFR 800 Caliper Mounting Boot Seal Reply with quote
I have been replacing my brake pads on my 2001 Honda VFR 800. When attempting to remove the front right caliber I mistakingly removed the Mounting Boot Seal. How important is this part in ensuring the brakes function correctly? Can I replace it?
kramdra
PostPosted: 00:39 - 30 Oct 2015    Post subject: Re: Motorcycle VFR 800 Caliper Mounting Boot Seal Reply with quote
Has it split or damaged? if not theres no reason it cant be reused. Yes it is very important, it keeps road dirt out of the sliding pins.
Ottocle
PostPosted: 03:33 - 30 Oct 2015    Post subject: Reply with quote
I damaged it when trying to put it back on. I've ordered another but am not sure how to install it properly (hence the original damage). Any advice about installation?
bamt
PostPosted: 06:24 - 30 Oct 2015    Post subject: Reply with quote
A smear of red grease on the outside helps it slip through the hole in the caliper. I've found it easier to put the open end through first - squish it down so it fits into the hole, and you can probably grasp it from the other side to pull it through. The closed end doesn't go through as easily (in my experience, everyone else will probably say I do it wrong!).
Whilst it's out, make sure the hole in the caliper is clear of corrosion - this can build up and close up this seal a bit so that the caliper doesn't slide as easily as it should.
PostPosted: 11:15 - 30 Oct 2015    Post subject: Reply with quote
David silver sell them. They are £3.75 each. New ones are very easy to fit.
PostPosted: 16:38 - 30 Oct 2015    Post subject: Reply with quote
And in this example, also reduces the internal diameter of the hole in the alloy casting to closer match the external diameter of the pin.
Missing it out is not an option, the pin would (literally) rattle about in the hole.
The last post was made 11 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 52.7 Kb
