white smoke from Header after service
Simba76
PostPosted: 08:53 - 31 Oct 2015    Post subject: white smoke from Header after service Reply with quote
I had a full service done on my SV650 and they found no issues with the engine itself.
They Changed all fluids and said the oil and coolant was long overdue a change.
After a week of riding, approx 200 miles I noticed after a 30 minute trip back from work that there was white smoke coming from the exhaust connection to the engine. The header I think(?).
There is a smell of burning as well.
I have no temp gauge.
I've checked the coolant and its still completely full so no leak there.
Could it be residue from the fluid changes?
I haven't noticed a drop in power significantly either.
If you can keep your head while all around are loosing theirs....you're probably in some sort of Zombie movie!
-Current bike ......
PostPosted: 09:29 - 31 Oct 2015    Post subject: Reply with quote
Would forget about that and change the front...possibly rear tyres at your earliest convenience.
Wonko The Sane
PostPosted: 10:13 - 31 Oct 2015    Post subject: Reply with quote
I always get white smoke and oil burning smell from my bike after I've changed the oil,
This is because I've not worked out how to do it without spilling oil on the collector box (where my exhaust goes from 4 into 2) so as the exhaust heats up it burns the oil off.
PostPosted: 10:24 - 31 Oct 2015    Post subject: Reply with quote
Soapy water or engine degreaser, scrub down the engine and header, take it out for a thrash. If it does it again, then worry about it.
Also, needs a fender-extender. It looks like one has been on there, or at least started to fit it.
Simba76
PostPosted: 11:03 - 31 Oct 2015    Post subject: Reply with quote
I'll give it a scrbb down and the take it for a blast.
The fender extender had some lovely screws in which still had sharp points in the end.
I'm filing them off before refitting.
The tyre looks properly squared off in the picture but its just the dirt from the journey. its only about 400 miles old.
SQL
PostPosted: 11:20 - 31 Oct 2015    Post subject: Reply with quote
Its more the model of tyre
Simba76
PostPosted: 17:36 - 31 Oct 2015    Post subject: Reply with quote
Are they not good?
Carvel
PostPosted: 17:43 - 31 Oct 2015    Post subject: Reply with quote
Bt-021s?? No they're shit.
Ben90
PostPosted: 17:56 - 31 Oct 2015    Post subject: Reply with quote
https://www.sportbikes.net/forums/attachments/fz6-fz6r/155595d1206745451-flashing-slide-easy-oil-change-img_1105.jpg
or cut up an old juice carton Thumbs Up
Yamaha FZ6 S2
Wonko The Sane
PostPosted: 19:38 - 31 Oct 2015    Post subject: Reply with quote
It's not the sump plug drain, it's the filter, it's a tight fit to get the filter in and out, only way it fits through is to turn it so the hole is at the bottom so anything else you add in there is in the way
The last post was made 11 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 66.44 Kb
