Help! Inspection cover stuck
craigster266
PostPosted: 15:26 - 31 Oct 2015    Post subject: Help! Inspection cover stuck Reply with quote
I'm trying to remove the inspection cover on the crank case of my YBR125 so I can do the valve clearances, but the thing won't budge. It's made of plastic and, despite using a large wide screwdriver, the thing is just chewing up. I don't mind replacing it, but any ideas how I can remove this?
Burnzy1989
PostPosted: 16:41 - 31 Oct 2015    Post subject: Re: Help! Inspection cover stuck Reply with quote
Try warming it up with a hair dryer, but I think it might not work . or if your replacing it drill two holes apart from each other so you can push two nails in the hols but make sure its a tight fit and then put a screw driver in-between them and make sure the screw driver is on top of one and below the other one and push down so it un does the cap
PostPosted: 17:36 - 31 Oct 2015    Post subject: Reply with quote
Drill two small holes in it opposite each other. Put a short self-tapping screw in each hole and use a screwdriver across the screws to undo.
Try not to screw the cover to the threads by putting the holes too near the edge.
Suntan Sid
PostPosted: 18:37 - 31 Oct 2015    Post subject: Reply with quote
Find a socket of, roughly, the same diameter, cut out a piece of plate metal that fits inside and across the diameter of the socket and you'll have made the giant screwdriver you require!
WD Forte
PostPosted: 19:35 - 31 Oct 2015    Post subject: Reply with quote
I've used large-ish washers that fitted the slot width snugly
then dressed them with a file so they bottomed nicely in the slot
then held them in the jaws of mole grips/shifting spanner/whatever is to hand and pressed them in whilst turning.
Screwdrivers will just chew the slots
Taking the time to make a suitable tool will be quicker and less of an arse ache in the long run.
I always give the threads and O ring a good dollop of copperslip before assembly which makes the job so much easier and quicker the next time.
bikers smell of wee
cb1rocket
PostPosted: 16:13 - 01 Nov 2015    Post subject: Reply with quote
Tyre levers are good, the ones with a flat edge
Ed Case
PostPosted: 16:37 - 02 Nov 2015    Post subject: Reply with quote
Firstly order a new one, then a light hammer and a sharply pointed punch to the existing one. If it isn't knackered by now it soon will be.
craigster266
PostPosted: 18:21 - 02 Nov 2015    Post subject: Reply with quote
Do you drill them all the way through, obviously taking care not to catch the flywheel?
Raffles
PostPosted: 20:41 - 02 Nov 2015    Post subject: Reply with quote
Pissed-off with chewing-up inspection covers etc, I decided to purchase one of these:-
https://s22.postimg.org/a9ndiz6qp/IMG_5835_1.jpg
It only cost me around seven ponds and is much easier and betterer than fucking around with Heath Robinson solutions.
Robby
Dirty Old Man
PostPosted: 22:48 - 02 Nov 2015    Post subject: Reply with quote
Hold a coin in a pair of grips. Tends to fit the slot well.
The last post was made 11 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 62.82 Kb
