Which license for 250cc?
VazNI
PostPosted: 20:40 - 01 Nov 2015    Post subject: Which license for 250cc? Reply with quote
Hi all
Am really considering getting a bike for the work commute on good days
I do just short of 40 miles each way to & from work so it makes sense, easier on fuel and getting through traffic quicker (dense jams most days)
Had a look at the 125cc's but most have a max speed of 50-60 mph, so would need to go to the 250's for motorway speeds
Most if not all 250cc seem to be class A2
Now I'm not up on the driving categories, or how to attain them, the dvla website is a bit confusing
I am 21 and have been driving for just over 3 years, what hoops do I need to jump through to be able to get a 250cc bike? And if I do the appropriate tests will I then be put on 'R' plates as with the car, or not allowed on motorways, etc for a given time?
Appreciate all feedback, thanks
john24ssj
PostPosted: 20:45 - 01 Nov 2015    Post subject: Reply with quote
Well to ride a 125 you only need to have to do a CBT(Compulsory Basic Training) and for 2 years you can ride a 125cc bike with L plates.
To get a full A2 license (for bikes with max 35 kW(47bhp)) you will need to do:
1 - CBT(Compulsory Basic Training)
2 - Theory test
3 - MOD 1
4 - MOD 2
https://www.doble.co.uk/images/latestNews/what-can-you-ride-2013/What-you-can-ride-3DLD-licence-categories-1-large.jpg
Bikes: Honda CBR600Fi, Kawasaki ER5
Andy_Pagin
PostPosted: 20:47 - 01 Nov 2015    Post subject: Reply with quote
^^ This, plus a provisional motorcycle entitlement on your driving licence.
There's no need, or advantage to restricting yourself to a 250, look for an A2 compliant 500cc instead. There's a lot more to choose from, they're near to the power limit for A2 and a much better riding experience. 250s tend to be little more than 125s with a teenie bit more power, whereas a restricted 500/600 is more like a full power big bike, just not quite so quick.
john24ssj
PostPosted: 20:50 - 01 Nov 2015    Post subject: Reply with quote
Don't think you need it if you already got a full car license
Andy_Pagin
PostPosted: 20:52 - 01 Nov 2015    Post subject: Reply with quote
If it ain't specifically stamped on your particular licence, you aint allowed to ride/drive it.
VazNI
PostPosted: 21:04 - 01 Nov 2015    Post subject: Reply with quote
Thanks gentlemen
That big poster thing clarifies it alot
Is there much difference in mpg between a 250cc and 500cc? MPG is one of the main factors I am after
I have cat B, B1 & fkp (beside it: code 11B) - no idea what the fkp code 11B means, google would suggest moped amongst other things, but double Dutch to me and it isn't too clear
edit: the code is probably 118 rather than 11B - no specs on!
john24ssj
PostPosted: 21:14 - 01 Nov 2015    Post subject: Reply with quote
VazNI wrote:
Thanks gentlemen
Depends on the bike, carbs of fuel injected. but here is a good thread about it: https://www.bikechatforums.com/viewtopic.php?t=193642
trevor saxe-coburg-gotha
PostPosted: 21:40 - 01 Nov 2015    Post subject: Reply with quote
Yeah not sure - I have a 250 4t single and also ride a 500 twin. But I don't pay any attention to mpg on either. I'd guess the former uses about 30% less petrol - maybe 40%. The 500 does between 50 and 60 mpg iirc. However if you factor in getting your license, buying some clobber, purchasing a bike, etc., you could well be a couple of grand in the hole. Recouping that on either a 250 or 500 will take a little while, especially when you factor in replacing consumables (chain, sprockets, tyres, etc.), and general maintenance if you can't DIY. Perhaps a 250 will mean your outlay is returned 6 months sooner than a 500 - but the real question is how long it will take to get your investment back more generally. A weekly winter commute of 400 miles will test your resolveat times, and your bike as well.
Gunge
PostPosted: 22:38 - 01 Nov 2015    Post subject: Reply with quote
I am not sure what the rules are regarding R plates - I did my car test in NI many years ago and my bike test in England a few years ago so it didn't matter to me.
Keep in mind most posters on here are answering from a mainland UK perspective and there may be some differences in requirements for NI (such as 45 mph limits...).
iooi
PostPosted: 22:42 - 01 Nov 2015    Post subject: Reply with quote
Don't just factor MPG.
I found that a 600cc bike was cheaper to insure than a 250cc bike by quite a margin...
My 250 did approx 50 mpg. my 600 averaged 60 mpg. Less stressed engine, as you are not at full throttle on NSL
Gunge
PostPosted: 22:52 - 01 Nov 2015    Post subject: Reply with quote
Done your homework for you:
L plate rules seem pretty similar apart from 45 mph rule
https://www.nidirect.gov.uk/motorcycle-licence-requirements
R plates must be displayed after passing, but the 45 mph rule doesn't apply to A2 or A bikes
https://www.nidirect.gov.uk/index/information-and-services/motoring/the-highway-code/annexes-to-the-highway-code/motor-vehicle-documentation-learner-and-restricted-driver-requirements.htm (Right at the bottom of the page)
talkToTheHat
PostPosted: 03:13 - 02 Nov 2015    Post subject: Reply with quote
It really does depend on engine design, look at the NC700 as the poster child for efficiency. The wider the throttle opening, the lower the pumping losses, and the lower the rpm, the less frictional losses, but modern ride-by-wire bikes can do clever tricks to save fuel although sometimes at the expense of a smooth throttle response, especially off idle. Further consider that an expereinced rider may filter through traffic smoothly rather than dawdle through stop start traffic which will save time and petrol. An air cooled 250 will have wider tolerences than a water cooled 250 and thus have worse efficency. If it is carbed, it will be even worse as it will be jetted rich to account for a wide range of temperature.
I think the last 10000 miles have cost me 1300 pounds in petrol, so it's by far the biggest expense for me including buying the bike. I could save money by riding economically, but that only happens on the rare occasons I need to use the fuel reserve and the reserve switch actually works.
Check reviews and fuelly.com for real world fuel economy. Ride a big bike like you're afraid to make any noise and you might get some pretty good fuel economy. Scream out of every corner up to warp speed and hard on the brakes into every corner and you'll say farewell to your spare change.
Whilst you can probably get similar fuel consumption out of a 500 and a 250, the bigger bike will probably drink more petrol if you ride it like you mean it.
Bandit. does. everything.
The last post was made 10 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 75.6 Kb
