| simon1221 |
 simon1221 World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
| Dom_ |
 Dom_ Points Mean Prizes
| TomC |
 TomC Trackday Trickster
| Dom_ |
| TomC |
 Posted: 01:20 - 10 Feb 2005 Post subject: |
For the top end rebuild, in addition to the bits Dom_ mentioned you will also need piston circlips (or "oh shit clips", as that is what you say when you try and put them in and they fly across the garage).
Might also be worth fitting a new little end bearing.
To be honest although I would be quite happy using pattern gaskets on a TZR I would be very tempted to stick with an original Yamaha piston and rings.
| Frost |
 Frost World Chat Champion
 Posted: 02:35 - 10 Feb 2005 Post subject: |
No doubt with some looking around you will find some deals.
For the RGV it was £150 for:
2 Pistons
4 Piston clips (2 per piston)
2 Base Gaskets
2 sets of piston rings
As you only need half of that it should cost around £75 for the lot.
You can do it without touching the head gaskets, but its normally only an extra tenner for the full set so you might aswell. |
| Git |
 Git Brolly Dolly
| sickpup |
 sickpup Old Timer
| bish777 |
 bish777 World Chat Champion
| simon1221 |
 Posted: 17:42 - 10 Feb 2005 Post subject: |
I presume you are replacing the piston and rings. These will probably come as a kit, maybe with the circlips.
Do not reuse piston circlips. The are subject to quite a lot of stress, and if you should jump out it will wreck the piston and bore.
Yes you do need to run it in. Generally a couple of hundred miles are half the red line max, then build up towards the red line over the next couple of hundred miles.
| simon1221 |
| Git |
 Git Brolly Dolly
| simon1221 |
| TomC |
The last post was made 21 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
