| chickenstrip |
 chickenstrip Super Spammer
 Posted: 10:23 - 02 Nov 2015 Post subject: Guitar Set-Up Question |
Bought the Strat with 9s, switched to 10s. But these seem to have put a lot more tension on the bridge, so it's lifting at the back, and the tuning is unstable; especially a problem when swapping between different tunings, it all takes forever and then quickly goes out of tune (knew there was a reason I preferred non-trem ). So, I have the option of a free set-up at PMTs, but wondered if it was easy enough, something I could learn to sort for myself first? Any ideas/tips/how-to?
I seem to remember sorting this on a previous guitar simply by adding 2 extra springs on the trem, but perhaps not the ideal solution (worked though)? ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 11:22 - 02 Nov 2015 Post subject: |
Take the cover off the hole, on the back of the body, and tighten the two screws that hold the spring mechanism to the body of the guitar.
That's worked for me in the past. ____________________ "Everybody needs money, that's why they call it money!"  |
| P. |
 P. Red Rocket
| oldpink |
 oldpink World Chat Champion
| chickenstrip |
 Posted: 12:49 - 02 Nov 2015 Post subject: |
| Suntan Sid wrote: | Take the cover off the hole, on the back of the body, and tighten the two screws that hold the spring mechanism to the body of the guitar.
That's worked for me in the past. |
| Paddy. wrote: | Loosen the strings a bit, drop it a step and a half. Remove the cover if its got no holes already, as Suntan Sid says, screw them in. |
Cheers chaps, have screwed them in a few turns, and seems to have done the trick Will see for sure when I change out the rusty bits of barbed wire for some fresh strings
| Paddy. wrote: | You think that trem is hassle, try a floating one. |
I once had a Washburn G2V with Floyd Rose - just changing strings was a pain on that bloody thing.
| old pink wrote: | you may need to give the truss rod a tweak as well as you have changed the tension on the neck
maybe better to take the free setup unless your comfortable adjusting the truss |
As said, seems ok, but I'll see how it is with new strings later. How would I know if this is necessary? And is it easy to do? ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| oldpink |
| chickenstrip |
 Posted: 23:12 - 02 Nov 2015 Post subject: |
New strings and given a hammering. No buzzes, all sweet
Cheers again. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| P. |
 P. Red Rocket
 Posted: 07:46 - 03 Nov 2015 Post subject: |
I used to have to adjust the truss rod on mine every few weeks... then I got multiple guitars. Going from B standard and 13 gauge to Eb on 10s was effort
Glad it's better chickenstrip |
| chickenstrip |
 Posted: 10:40 - 03 Nov 2015 Post subject: |
| Paddy. wrote: | I used to have to adjust the truss rod on mine every few weeks... then I got multiple guitars. Going from B standard and 13 gauge to Eb on 10s was effort
I used to use 11-52 gauges (SRV fan - he used 13-52 ); nice tone, but they tore my fingers to pieces with all the string bending Hence going from 9s to 10s - the 9s don't last 5 minutes. Haven't played the electric for a couple of months, so even 10s are giving me sore fingers at the moment, but they'll soon callous up again.
On the acoustic, I don't have the same problem. Don't do quite as much string bending on that, and tend to let the tuning drop from standard, as I'm only playing by myself anyway, and I go relatively light with the gauges on that - 10s too (Martin extra lights). Have to capo at the 2nd fret on that though as my dodgy shoulder doesn't like reaching down to the nut a lot. This actually gives quite a nice sound for some of the stuff I play on the acoustic. Also, I use 4 or 5 different tunings on the acoustic for different stuff I play. On the electric, I tend only to go from standard to open G for slide playing. Never needed to adjust the action for that, and I haven't a clue about setting up - I'm not one to get technical with guitars, I just play em! ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| oldpink |
| chickenstrip |
 Posted: 15:13 - 03 Nov 2015 Post subject: |
| oldpink wrote: | latest addition to the collection my son bought Schecter 8 which he plays in all sorts of drop tuning
I can't play his 7 string never mind this beast |
Oooh, Schecter, get you! Flash git! Bloody expensive aren't they? Only person I can think of that plays those is Mark Knopfler, or he used to.
No, 7 & 8 string I won't be getting my head around! Wouldn't mind a nice acoustic 12 though, could work nicely with some of the celtic style tunes I play, that need a drone underneath. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| P. |
 P. Red Rocket
| chickenstrip |
 Posted: 15:40 - 03 Nov 2015 Post subject: |
| Paddy. wrote: | Schecter. The latter are superb, for the money you really can't beat it. |
I always had the impression that price-wise, these were pretty exclusive - not that I've followed trends lately. I used to bunch them in with things like PRS and Gretsch as quality but super-expensive guitars, in my mind. Jeez, a brand new Fender Strat was enough to be laying out for, for me! Too much really, but I do like em, and hopefully I'll hang on to this one and get my money's worth. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| P. |
 P. Red Rocket
 Posted: 16:19 - 03 Nov 2015 Post subject: |
My 3 schecter guitars were between 700 and 1200. Nothing crazy when idiots spend over 2k on wood.
Nothing has really impressed me as much as my C7 hellraiser. |
| oldpink |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| someotherguy |
 someotherguy Crazy Courier
 Posted: 23:25 - 03 Nov 2015 Post subject: |
| P. |
 P. Red Rocket
| someotherguy |
 Posted: 10:38 - 04 Nov 2015 Post subject: |
| P. |
 P. Red Rocket
 Posted: 12:13 - 05 Nov 2015 Post subject: |
All bout the .88mm and 58-13's
I had a 7 string... it was superb, but you know... sometimes it was likely playing a plank, wider than my knob  |
| oldpink |
 Posted: 21:02 - 05 Nov 2015 Post subject: |
I can happily swap from a 6 to a 12 string and vise versa but I can't figure out a 7 string
esp as my son normally has his tuned to C or some other weird tuning
he uses heavy gauge strings to allow the drops
he even has my Godin on 13's but in Dd tune (no idea why)
but means I can't tune to E as it pulls the neck way off and makes it feel like a slide guitar
my personal string choice is Elixier 10 - 46 esp on the 12's but bloody expensive
esp when you have 3 main 12's to do at any one time ____________________ I have become comfortably numb
Theory & hazard 24-may 2016, CBT 8th June 2016, MOD 1 2nd Aug 2016 Mod 2 2nd-Nov 2016 - Current bike CBR 600 RR |
| Fladdem |
 Fladdem World Chat Champion
 Posted: 21:10 - 06 Nov 2015 Post subject: |
I bought a used Squire Jagmaster recently, what a guitar, it came with 9's, I stuck 11's on it, after snapping the 9's within two weeks, when tuning it, it pulled the tremolo bar thing up, so I just stole two more springs from the back of the china-strat I was using to thrash around on, that seemed to sort it, it wasn't until afterwards, I noticed the screwed going into the body and realised that I probably could have just tightened them down more to adjust spring tension.
Never mind, china-strat sounds funny with only one spring in it and Jagmaster sounds as evil as ever, s'all good.
EDIT: Just read some of this and have no idea what half of thread is saying. It's dawned on me just how little I actually know about guitars, I can't read music, I don't know any keys or scales, don't know what anything is called on a guitar, but I can make feedback happen and smash out palm-muted 5th's like there's no tomorrow.  ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| i.p.phrealy |
 i.p.phrealy World Chat Champion
 Posted: 23:16 - 19 Nov 2015 Post subject: |
I quite agree! got them on my old Fernandes.
playing bass almost exclusively means when I do play guitar 9s feel like rubber bands to me. ____________________ it is impossible to lick your own elbow...
Finally allowed a big bike 19/03/14! |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 12:56 - 23 Nov 2015 Post subject: |
Id advise most guitarists to stay away from tremeloes and dodgey bridges . i had a yamaha with springs in the back , after pi***ing around with it for a few months I added a few extra screws to fix the bridge ,took of the trem arm and sold , not mentioning the tremelo .
Thesedays when tremeloing I just pretend im trying to snap the guitar by pulling backward on the neck ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 10 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
