Suzuki gsx1100f cutting out
Tinkering
PostPosted: 22:03 - 03 Nov 2015    Post subject: Suzuki gsx1100f cutting out Reply with quote
Can anyone help? It starts on 3 then immediately cuts out?
IF ITS GOT AN ENGINE... TINKER 😉
Tinkering
PostPosted: 23:11 - 03 Nov 2015    Post subject: Suzuki gsx1100f streetfighter Reply with quote
I am wanting a wider rear wheel. Can I do this just by changing the wheel if so, what wheel? Or do I have to change the swing Arm? If so, what swing arm?
Tinkering
PostPosted: 20:11 - 04 Nov 2015    Post subject: Reply with quote
Cheers for that I was wanting something like a 180 / 190 width.
I want to change the swing arm to something nicer?
Ariel Badger
PostPosted: 22:17 - 04 Nov 2015    Post subject: Reply with quote
Did you fix the first problem 8 mins after posting and just move on to something else?
Tinkering
PostPosted: 22:40 - 04 Nov 2015    Post subject: Reply with quote
No I've bought it as a street fighter but it's rough and I just want to clean it right up as a project to work on with my father and son. Have you any ideas you'd like to share?
Ariel Badger
PostPosted: 23:44 - 04 Nov 2015    Post subject: Reply with quote
You say it starts on three and then cuts, let us first look at the cylinder that does not fire. Could be plug, lead, coil, carb (I think this is a carbed bike) or compression. All easy if time consuming to sort. Then there are the three that cut, this will be a comon fault so we can dismiss plug, lead, coil or compression this leaves us with carbs. My best bet is fuel pump or a blocked vent.
Tinkering
PostPosted: 23:20 - 05 Nov 2015    Post subject: Reply with quote
I'll be testing and tinkering this weekend as I've never even had time to test anything yet, I've only had it since Sunda but, I'll be posting my findings.
Cheers for your help and advice and keep posting any thoughts and ideas for our project... Much appreciated
Lee
The last post was made 10 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 58.84 Kb
