setting up carbs and jetting.
stevo as b4
PostPosted: 18:38 - 07 Nov 2015    Post subject: setting up carbs and jetting. Reply with quote
Hi, This is just basically a question for anyone that's bought new aftermarket carbs, and paid for dyno time and expertise to have them set up properly.
What did you do regarding jetting in terms of having a range of jets and needle's and slides available on the day? Did you supply your own range of jets and needles etc, or did the tuning firm stock them?
I've got a carb to get set up, that I've had pre-jetted at purchase to the specs of another engine using the same capacity per cylinder, and then I've gone up a size on everything.
I've got main, pilot and power jets a few sizes either side of this, but no different needles as I wouldn't have known what to order.
I'll obviously be speaking to the tuner/dyno operator before going, but i don't want to waste a few hours of expensive dyno time for the sake of not having the right jets or needle required on the day, and then have to go back again.
Finally what are peoples thoughts on fitting a new carb and then if it seems to run okish, riding to the dyno centre on a base setting, or should the bike always go in a van?
I'm not buggering around with this bike trying to read spark plugs that give misleading results, and trying to self jet a brand new carb, that's too much ball ache for me!
stirlinggaz
PostPosted: 19:17 - 07 Nov 2015    Post subject: Reply with quote
hi,
I dunno what bike your fitting this carb to, but im sure your not the 1st to do it.
why not ask in forums specifically for that bike? or even a fb users group?
there should be owners who have already tried this mod & should be able to point you in the right direction.
has to be better than going in blind....its something I have done in the past.
cheers,
GAZ
.. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:32 - 07 Nov 2015    Post subject: Reply with quote
If you are booking dyno time and have told them which carb you have and they don't have suitable jets I'd be looking at a refund.
Triumph Sprint ST 1050
stevo as b4
PostPosted: 21:51 - 07 Nov 2015    Post subject: Reply with quote
TBH, I'm sure they will have plenty of suitable Mikuni jets, as they do this sort of thing all the time. But I've never had a professional dyno tune done before, as was unsure if it's a good idea to supply the jets that you think might be needed to get it spot on.
I don't care how long the set up takes, I just don't want it to be a case of we need the XYZ needle to finish the job perfectly and we havn't got one, so please come back for more bike torture next time. Laughing
I've played around re-jetting scooters and bikes before, and with my speedfight I got the main jet fairly close, but couldn't get the other circuits tuned very well, so I can't be bothered with messing around, or melting things.
The last post was made 10 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 45.74 Kb
