Anyone got any ideas on how to do this but neater?
The Artist
PostPosted: 22:25 - 07 Nov 2015    Post subject: Anyone got any ideas on how to do this but neater? Reply with quote
https://i.imgur.com/bd2DiU1.jpg
I have a pair of crocodile clips going to an anderson connector, much like the picture above except about 4M of cable between the two. I am planning on using twin core cable like this.
https://i.imgur.com/0bcElEp.jpg
My concern is the point where I remove the outer casing will look crap and will be prone to damage. I don't like the idea of putting a big piece of heatshrink over it either because it will still look awful. I have been looking for a Y shaped plastic housing I can put over the end but I haven't found anything decent.
I also don't want to use a bulky junction box like this.
https://i.imgur.com/mYgWHop.jpg
Unless it was really small. The cable I am thinking of using is twin core, with each core being 1mmsq.
So has anyone got any ideas?
kramdra
PostPosted: 00:26 - 08 Nov 2015    Post subject: Reply with quote
Wrap in self amalgamating tape with cloth tape (rubber adhesive type) over the top. This will protect it from damage.
ScaredyCat
PostPosted: 00:41 - 08 Nov 2015    Post subject: Reply with quote
Never used it myself but might be worth a try...
https://www.plastidip.co.uk/shop/liquid-electrical-tape
Liquid Electrical Tape is an air-dried, synthetic rubber coating that can be brushed on. It exhibits excellent moisture, acid, alkaline, abrasion and dielectric resistance.
This product offers a far more efficient sealing method when compared with sticky cable seals and tape. Perfect for quick access and portability!
L.E.T. remains flexible even under extreme conditions and won't crack, harden or peel.
Electrically insulates to over 1380volts/ml.
Liquid Electrical Tape is excellent for use in a variety of applications including :
Connections and components for boats, trailers, cars and trucks, timers, outdoor wiring, instruments, computers, circuit boards, switches, radio antennas and many more.
Easy to remove from non-porous surfaces.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
WD Forte
PostPosted: 00:48 - 08 Nov 2015    Post subject: Reply with quote
Nowt wrong with heat shrink if used correctly.
it will give you a more compact joint than anything else.
bikers smell of wee
ferrisio
Tech flex with heat shrink at the ends?
BMW R1100R
The Artist
PostPosted: 01:05 - 08 Nov 2015    Post subject: Reply with quote
I should point out that this is for a product that is being sold so self amalgamating tape isn't really an option. It is got to be long lasting and so heat shrink/plasti-dip won't be tough enough.
Closest robust thing I have found so far is basically the same as this.
https://i.imgur.com/EQrJeMF.jpg
That is still too big though and the ports are just tube, no threads or anything.
The Artist
PostPosted: 01:16 - 08 Nov 2015    Post subject: Reply with quote
Right, I have found a picture of exactly what I need.
https://i.imgur.com/15Hcox9.jpg
orac
PostPosted: 06:59 - 08 Nov 2015    Post subject: Reply with quote
providing its not going to get hot, polymorph. its freaking brilliant stuff for moulding round things.
Andy_Pagin
PostPosted: 11:01 - 08 Nov 2015    Post subject: Reply with quote
If it's for a product, why not contact an electrical component wholesaler or manufacturer and have a proper batch of whatever you need made up?
The Artist
PostPosted: 13:17 - 08 Nov 2015    Post subject: Reply with quote
For the moment, I only need ~15.
Polymorph looks like I would need some sort of mould. I was hoping for something off the shelf that would just clamp down on the wires. I might end up using something like this.
https://i.imgur.com/RdNETcn.jpg
Although they are still kind of large.
J4mes
PostPosted: 13:26 - 08 Nov 2015    Post subject: Reply with quote
https://uk.rs-online.com/web/p/cable-moulded-parts/2181426/
Y-joint cable boot.
The Artist
PostPosted: 13:55 - 08 Nov 2015    Post subject: Reply with quote
Y-joint cable boot.
Perfect but too large unless I use larger diameter cable. I am looking at using 1mm twin core with a diameter of 4.9mm on the outer casing.
J4mes
PostPosted: 13:58 - 08 Nov 2015    Post subject: Reply with quote
RS sell them in other sizes.
It was just as an example, and so you know what they are called. You might be able to trawl the interweb for ones in your size.
The Artist
PostPosted: 14:12 - 08 Nov 2015    Post subject: Reply with quote
Yeah I had a look. All bigger. Laughing I am thinking of maybe bulking up the cable with heat shrink and then using one of those Y cable boots.
J4mes
PostPosted: 14:23 - 08 Nov 2015    Post subject: Reply with quote
Ah Laughing
PostPosted: 15:22 - 08 Nov 2015    Post subject: Reply with quote
An inline jack socket with strain relief.
Drill out the centre so the two wires just come out the end (or chuck the insert altogether and just use the outer boot).
https://cpc.farnell.com/pro-signal/psg02799/2-5mm-jack-socket-in-line-mono/dp/AV17314
The Artist
PostPosted: 22:57 - 08 Nov 2015    Post subject: Reply with quote
I think this might be the best option. Hopefully I can find one that fits nice and tightly. Thumbs Up Karma
sickpup
Old Timer
PostPosted: 09:27 - 09 Nov 2015    Post subject: Reply with quote
Anderson connectors are rated at something like 180amp at 12v, will 1mm cable fit in the clamp?
J4mes
PostPosted: 10:00 - 09 Nov 2015    Post subject: Reply with quote
The conventional ones come in sizes down to 50a, but I think you'd be better using the power pole range.
What is it you're building?
Would tamiya connectors do it?
The Artist
PostPosted: 14:06 - 09 Nov 2015    Post subject: Reply with quote
Only baby ones. They go down to 15A.
https://www.powerwerx.com/anderson-powerpoles/powerpole-sets/15-amp-red-black-anderson-powerpole-sets.html
The Artist
PostPosted: 14:10 - 09 Nov 2015    Post subject: Reply with quote
I am panel mounting one side of the Anderson connectors with this kit.
https://i.imgur.com/Ha1qGWC.jpg
Tamiya are kind of cheap looking and not as robust as powerpole IMO.
J4mes
PostPosted: 16:18 - 09 Nov 2015    Post subject: Reply with quote
Hey even my optimate uses tamiya connectors! But I would agree that against a PowerPole they do look cheap.
Should have known they go down to 15amp, I have a pack of them in the garage Embarassed
So what are you making? Mr. Green
The Artist
PostPosted: 16:35 - 09 Nov 2015    Post subject: Reply with quote
MKII of www.ukht.co.uk
J4mes
PostPosted: 17:29 - 09 Nov 2015    Post subject: Reply with quote
In that case up the cable size and use the proper cable boot, don't bodge things to fit. It doesn't look professional. And people involved in the work your equipment is designed for will spot a bodge a mile off I expect.
The Artist
PostPosted: 18:11 - 09 Nov 2015    Post subject: Reply with quote
Yeah, I am looking at lots of different options at the moment. I have so much single core wire around and now I need to buy another 100M of twin core. 4mm would be nice but so expensive.
The last post was made 10 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 124.87 Kb
