fzs 600 strange back end behaviour
Hahadumball
PostPosted: 15:48 - 08 Nov 2015    Post subject: fzs 600 strange back end behaviour Reply with quote
98 fzs...
the rear end feels like i have a flat tyre when cornering, feels fine when im going straight and once i get over the initial flat tyre feeling and lean more its fine however at high speed it does have a little wobble.
wheels ballanced
bearings are new and no wear on the hub
sprocket and chain all good condition
chain is straight and not kinked/dry/derp
swingarm fine
it seems to happen a lot more when i lean left and barely does it on right corners...
the tyre "looks" okay but is it possible for it to cause this? theres no obvious buldges or anything on it.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Robby
Dirty Old Man
PostPosted: 15:53 - 08 Nov 2015    Post subject: Reply with quote
Any chance it also feels like you're about to die when you go over white lines?
Check the head bearings. Put it on the centre stand, get jack under the engine to get the front wheel off the ground, and gentle move the bars lock to lock. Feel for a click or a clunk as the wheel points dead ahead.
If they're totally fucked, like on one of my old bikes, you'll find it moves quite nicely within a few degrees of straight on - that means the bearings haven't just worn a groove, but have worn a deep smooth divot to settle in to.
Hahadumball
PostPosted: 19:35 - 08 Nov 2015    Post subject: Reply with quote
head bearings are slightly notchy i did intend on changing soon but its only on the back, it feels as if the back tyre is flat
pepperami
PostPosted: 19:59 - 08 Nov 2015    Post subject: Reply with quote
Not squared off is it? or old and hard?
STONEY!
PostPosted: 21:30 - 08 Nov 2015    Post subject: Reply with quote
Checked swingarm bearings? Had a lot of fazers with failed arm bearings.
Busa1340R
PostPosted: 09:20 - 09 Nov 2015    Post subject: Reply with quote
+1
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
Robby
Dirty Old Man
PostPosted: 09:45 - 09 Nov 2015    Post subject: Reply with quote
Often a problem that feels like it's happening at one end is actually at the other end - so knackered headstock bearings can make the back tyre feel like it isn't working, and knackered swingarm bearings can make the front feel funny.
You know the headstock bearings need doing, so sort them out before hunting for more problems. If the bike is generally a bit worn, I would also strip and clean the rear suspension linkage and the swingarm bearings. New grease makes a big difference, I recently did the rear suspension linkage on my VFR. The bearings were in good condition and still had some grease it, but over the years it had turned into something more like dirty water. They absorbed a surprising amount of new grease.
andym
PostPosted: 13:32 - 09 Nov 2015    Post subject: Reply with quote
I've found the back end on my bikes have been a bit twitchy on corners when the pressure is low (or squared off tyres)
Kawasaki Jimbo
PostPosted: 14:14 - 09 Nov 2015    Post subject: Reply with quote
Robby wrote:
Often a problem that feels like it's happening at one end is actually at the other end....
Spot on I'd say, speaking from personal experience.
Paul Fzs wrote:
the tyre "looks" okay...
An interesting experiment I've done occasionally is to use a flexy-curve ruler to draw the profile of worn tyre on paper, record date, mileage and tyre identity, then do the same to the new tyre. (Keep in mind that different tyres will have slightly different profiles unless you replace like with like.)
https://www.ryman.co.uk/helix-flexi-curve-ruler
Unfortunately I've misplaced the examples I had but my tyres didn't "square" so much as develop assymetry, wearing slightly more on the right. (Roundabouts, I guess.) By eye it didn't look too bad but I thought I could feel a subtle difference. I now commute 20 miles each way along a Roman road on a litre bike so my tyres probably do properly square off now. Sad
'93 Yamaha XJR400 grey import (p-ex’d), '99 Kawasaki ZX6R (nicked), another '99 ZX6R (still got it) and '03 Yamaha YZF-R1 (still got that too.)
The last post was made 10 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 62.03 Kb
