YZ 250 Yamaha 2 stroke casing hole.
cart_man
PostPosted: 10:49 - 09 Nov 2015    Post subject: YZ 250 Yamaha 2 stroke casing hole. Reply with quote
Hi.
I have a YZ 250 2 stroke that is roughly 9 years old. Recently it started leaking oil from the motor casing. So I checked it out and it seems like I have a hole in the lower casing right in front of the front sprocket. It seems like my chain actually chipped away at it even though its nowhere close to it. I spoke to a couple of guys and they said that it is quite common for this to happen and that it is indeed the chain.
My question is HOW? And also how do I fix it?
My understanding is that anything yamaha is seriously expensive stuff never mind the belly of the motor casing Sad
Thanks
dangerousdave
PostPosted: 00:32 - 11 Nov 2015    Post subject: Reply with quote
Best way to repair is to track down another crank case, and replace it as a unit.
There are other options such as using liquid metal, or an alloy weld repair but how effective these would be i would not know. These are a bit of a bodge in my opinion. The alloy weld would require the crankcase to be split anyways so you would be better off just replacing it.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
PostPosted: 16:08 - 11 Nov 2015    Post subject: Reply with quote
Put up a photo don't have to take the engine apart should be able to weld it easy.
The last post was made 10 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 35.88 Kb
