Your preferred way to stop grips twisting/turning
trevor saxe-coburg-gotha
PostPosted: 12:45 - 09 Nov 2015    Post subject: Your preferred way to stop grips twisting/turning Reply with quote
What are some effective ways to stop grips from not uhm gripping the bars? A couple of my bike's have this and usually it doesn't bother me - I hold the bars so lightly that it's mostly not an issue. Yet it *is* a niggle at times, and although they're not baggy and loose, it's possible to get them to move without too much effort.
An old tip someone recommended was of all things hairspray. And this actually worked on one bike. But for whatever reason it's not working on another. I've whipped the grips off, cleaned them, cleaned the bars, waited until both have dried, and put 'em back on. Yet still there's this potentially annoying twistyness. Pissing me off now, if only because I can't seem to cure it. : - /
PostPosted: 12:53 - 09 Nov 2015    Post subject: Reply with quote
Hair spray the cheaper the better, or just any kind of glue really.
Doovy
PostPosted: 13:01 - 09 Nov 2015    Post subject: Reply with quote
I've always used hairspray (ooo-err, Matron), but Renthal Grip Glue is an option too.
Try new grips too?
Hairspray and lockwire.
PostPosted: 13:36 - 09 Nov 2015    Post subject: Reply with quote
Hairspray following a thorough de-grease of both the bars and inside the grips has always worked for me so far.
Matt B
PostPosted: 13:48 - 09 Nov 2015    Post subject: Reply with quote
What bars are you using?
Hairspray works best on normal smooth bars - like OE chrome ones. When it dries it forms a good seal between the grip and the bar and is normally solid.
On other bars like Renthals that have a knurled section for the LH grip hairspray doesn't seem to work as well.
Baffler186
PostPosted: 15:55 - 09 Nov 2015    Post subject: Re: Your preferred way to stop grips twisting/turning Reply with quote
Have they been through MOTs like that? Mine failed for a very slight lack of adhesion, or rather would have if the garage hadn't re-stuck them (for free). If the insides of the grips have worn away so much that they are no longer tight, it might be time for new grips, or I've used silicone sealer in the past because it's more bulky than glue and easier to get off if you need to.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
PostPosted: 16:45 - 09 Nov 2015    Post subject: Reply with quote
I had to resort to replacement grips. Guess mine had gone baggy over the years.
PostPosted: 17:26 - 09 Nov 2015    Post subject: Re: Your preferred way to stop grips twisting/turning Reply with quote
Just got an MOT this afternoon, so the answer is yes. No advisories, etc.
This are new grips on new boring black bars. Although they may not be original Honda grips. So there's that...
Will try lock wire then silicon gunk if wire fails. Cheers everyone.
PostPosted: 17:33 - 09 Nov 2015    Post subject: Reply with quote
Hairspray is the manliest way to stick your grips on. Wink
ADSrox0r
PostPosted: 17:55 - 09 Nov 2015    Post subject: Reply with quote
Tried a few ways but my top tip; clear bathroom silicone sealant. Works a treat doesn't budge and just peels off nice and easy when it's time to swap manky grips out.
FlightRisk
PostPosted: 18:33 - 09 Nov 2015    Post subject: Reply with quote
Was super glue a bad idea then?
Honda CB500S
MCN
PostPosted: 18:37 - 09 Nov 2015    Post subject: Reply with quote
EvoStick. Works and smells a treat. (After de-greasing the grips and bar/s)
Ariel Badger
PostPosted: 18:46 - 09 Nov 2015    Post subject: Reply with quote
Hairspray does it for me but I would advise against locking wire as one day it will stab your hand.
Fizzer Thou
PostPosted: 20:15 - 09 Nov 2015    Post subject: Reply with quote
Nothing wrong with lock wiring the grips in place so long as the twisted end is pushed right back into the grip.
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture040.jpg
As for affixing the grips into place I have always used Renthal grip glue.When I needed to remove the left hand switchgear so as to remove the clutch bracket for the new parts,I managed to remove the grip okay before cleaning everything up and reaffixing it with the Renthal glue.Finally,a twist of wire at each end of the grip ensured that it would not move again Thumbs Up
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture402.jpg
Always have a 'Plan B'
RhynoCZ
PostPosted: 20:17 - 09 Nov 2015    Post subject: Reply with quote
A fresh set of grips on perfectly cleaned and degreased bars. Thumbs Up
PostPosted: 21:41 - 09 Nov 2015    Post subject: Reply with quote
Ffs, try reading the motherfucking thread. Rolling Eyes
This are new grips
RhynoCZ
PostPosted: 21:46 - 09 Nov 2015    Post subject: Reply with quote
I did miss that, sorry. Well, glue is the answer then. Smile
MCN
PostPosted: 22:34 - 09 Nov 2015    Post subject: Reply with quote
Keep the grips sell the bike. Whistle
bamt
PostPosted: 22:47 - 09 Nov 2015    Post subject: Reply with quote
Drill through the grips and bar, thread an M6 bolt through them both, put a nut on the other side. Job jobbed. Smile
PostPosted: 01:35 - 10 Nov 2015    Post subject: Reply with quote
Resorted to superglue on the 675 - grips now 9 years old and really could do with replacing, but being cheap.
Normally hairspray is fine (and may well have been if I'd cleaned it all up properly first.)
notbike
PostPosted: 02:20 - 10 Nov 2015    Post subject: Reply with quote
Superglue. If I'm replacing them for whatever reason I'll just chop them off. Not likely though.
The last post was made 10 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 122.1 Kb
