VFR 400 Runs on 3 cyclinders after 10k rpm
mattevans58
PostPosted: 23:52 - 09 Nov 2015    Post subject: VFR 400 Runs on 3 cyclinders after 10k rpm Reply with quote
Just took my VFR for a spin and was having a blast, decided to pin it and I got to about 4th gear 12k rpm and all the power dropped and twisting the throttle further didnt increase the rpms it struggled and you could hear it was running on 3. I pulled over, the revs went to idle and the other cylinder fired up again and off I went again. I havent taken it to bits yet because its nearly 11pm so will tomorrow if I get the chance but at first I thought it was the fuel filter restricting the amount of fuel and killing a cyclinder but that didn't really make sense. When it fires up, its fires on all 4, can rev it in neutral and its fine but when I pin the throttle it goes blur.
Carbs are balanced and jetted perfectly.
I'm presuming it's plugs, leads or carbs but any experience?
And another thing, if it something that can only be checked when I go for it then thats a bugger....
redeem ouzzer
PostPosted: 00:07 - 10 Nov 2015    Post subject: Reply with quote
In all gears or just 4th upwards?
Old Git Racing
PostPosted: 00:14 - 10 Nov 2015    Post subject: Reply with quote
Start with the basics and put new plugs in, check plug leads at both ends for good connection and check plug caps are securely seated.
OGR
Ariel Badger
PostPosted: 00:29 - 10 Nov 2015    Post subject: Reply with quote
I would suggest you have a blocked main jet on that pot.
.Bishbash.
PostPosted: 10:01 - 10 Nov 2015    Post subject: Reply with quote
Anything like This?!?!?!?
Current bike - GSX-R1000 k8
smallfrowne
PostPosted: 13:31 - 10 Nov 2015    Post subject: Reply with quote
Ah man, bummer. Had some issues on mine and they were jetted and balanced fine Very Happy Only way to do it is to go through things logically.
I've had issues with a coil pack, identified by swapping them over, the issue moved with it from front cylinders to back. But that was only running on 2cyl that time.
I've had a brass float seat come loose a few turns in one of the carbs before. It acted in a similar way to as you described. With one pot out it ran fair enough until you wound it on, and then didn't quite rev out, getting to ~12ish and then blrrrrrrr. I'm guessing it wasn't letting the float needle open up fully so fuel didn't flow fast enough to keep up. Having sat a while at idle filling up it briefly ran fine again. But blocked jets might do similar (as mentioned), or something else float related like being stuck/blocked, not set quite right...
I'm also having an intermittent issue where the cdi is hitting the rev limiter before the tacho reaches redline orrr the tacho is reading too low. Either way it cleared up after turning the ignition off and on again a few times. But I've not heard of this problem before, pretty unlikely.
Is it restricted still? Can't remember what speed 12k is in 4th. Cdi will cut 2 cylinders at ~110mph.
I'd guess a fuelling issue. But arguably it's easier to check plugs, leads and coils before you whip the carbs off.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
mattevans58
PostPosted: 14:48 - 10 Nov 2015    Post subject: Reply with quote
I would say gears after 2nd or 3rd because when I went for it, I could rev out first and second and sometimes third then it'd go downhill from there
mattevans58
Replace or clean?
mattevans58
PostPosted: 14:49 - 10 Nov 2015    Post subject: Reply with quote
Sort of I guess. It just would not pick up for the life of it. It would physically require me to pull over and restart the engine to get all 4 back up again
.Bishbash.
PostPosted: 16:30 - 10 Nov 2015    Post subject: Reply with quote
That was a former bike I did up....I grew many a grey hair due to that bike.
OK, start with the plugs and HT leads(as suggested) Swapping them over etc, if they are all fine, then have a go at the carbs and give the jets a good clean out. When were the carbs balanced and jetted??? Recently? And when did the problem start?
Jefr0
PostPosted: 17:32 - 10 Nov 2015    Post subject: Reply with quote
My friend had the same problem.
There is a electronic speed restriction in the speedo. At a certain speed (like your 4th gear 12k revs) it would cut power to restrict it.
I'd suggest it's this. Changing plugs/coils etc could be avoided if you try 12k+ in the first 3 gears and see if it's fine and not just a speed restriction.
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
mattevans58
PostPosted: 20:25 - 10 Nov 2015    Post subject: Reply with quote
[/quote]
OK, start with the plugs and HT leads(as suggested) Swapping them over etc, if they are all fine, then have a go at the carbs and give the jets a good clean out. When were the carbs balanced and jetted??? Recently? And when did the problem start?[/quote]
All the plugs and leads are all fastened in correctly, all sparking. Stripped the bike this evening and the carbs are being given to a friend of mine who is a fantastic carb cleaner, they come back looking spanking new inside and out. Told him the details and he said he'd make sure they're in pristine condition for me so and get them rebalanced when they're put back on the bike. All for £20! So that'll rule out another problem. I can order new plugs and leads if needs be but I'd really rather not Embarassed
mattevans58
PostPosted: 20:27 - 10 Nov 2015    Post subject: Reply with quote
How do I go about removing said restriction or finding it? I bolted it earlier on the bike and got to 5th gear and back down to 2nd again and it didnt drop a cyclinder, but it did drop a cyclinder or 2, about 5 times on my ride out today. It just seems to be when the revs are held high for a period of time...
I've gotten into the habit of changing really early and just sitting in 6th all the time but it gets so boring Mad
bikertomm
PostPosted: 21:30 - 10 Nov 2015    Post subject: Reply with quote
This might be a really stupid suggestion, I don't really know.
When my CB600 started mis-firing it was a spark plug - even though it was new, the housing it was sitting in had come slightly loose which allowed the plug to bounce all over the shop causing intermittent firing (usually high in the revs because of the vibrations!)
May be worth a quick check. Solved with some rubber sealant Thumbs Up
Fladdem
PostPosted: 22:21 - 10 Nov 2015    Post subject: Reply with quote
At work, we had a dropped cylinder and misfire caused by a plug too. We'd put new plugs in as part of the service, but one must have been damaged internally so we couldn't tell. We never suspected because they were brand new, after eliminating lots of other things, we thought about swapping plugs and the misfired went with the plug. Weird. Laughing
mattevans58
PostPosted: 00:06 - 11 Nov 2015    Post subject: Reply with quote
by the sounds of it then I need some new plugs! Will get some new HT leads on top because they're only £36 on top so, when they're delivered and fitted i'll let you all know how it went!
craigs23
Mr Muscle
PostPosted: 19:07 - 11 Nov 2015    Post subject: Reply with quote
I had a similar thing on my Superfour, where the bike felt like it wouldn't exceed past 7k in top. Ended up being the Japanese 180kph restrictor in the speedo was faulty, and essentially restricting the bike earlier than 180kph. Fitting a new resistor in the loom to remove the restriction corrected the issue.
mattevans58
PostPosted: 19:32 - 11 Nov 2015    Post subject: Reply with quote
Upon some more reading, I read somewhere that the imported Japanese NC30's had a speedo restriction at 113mph by their laws. Once youd reach 113 the restriction would drop 2 cyclinders and youd have to slow down again to get them firing (sounds just like my issue). To overcome this you either fit a a MPH speedo or use a speedo translater from kph to mph....and I JUST so had an NC30 speedo converter laying in my toolbox. Will post back tomorrow if the issue is still there.
Bikeless
PostPosted: 00:05 - 12 Nov 2015    Post subject: Reply with quote
Or temporarily disconnect the speedo cable to test.
mattevans58
PostPosted: 03:27 - 20 Nov 2015    Post subject: Reply with quote
Update -
My carbs is still of at a friends being cleaned, and rejetted for a new exhaust, also putting Rick O's carb needles in to reduce the midrange flat spot NC30's have. The bike is to be put in storage in the next month or so as I start my Marine training soon. Oil's been changed and flushed, new oil filter, air filter, throttle and clutch cables, new brake pads, plugs all round, new HT leads all round, thorough clean up and awaiting the carbs to be put back on and balanced then I shall have to see if the issue has gone, although I am 99% sure it's the speedo restriction.
Thanks all again, I would never had known about the speedo restriction if someone hadn't have mentioned it, cheers! Very Happy
The last post was made 10 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 108.18 Kb
