Offsiding on country roads
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5, 6  Next
BBR
PostPosted: 14:45 - 10 Nov 2015    Post subject: Offsiding on country roads Reply with quote
Anyone know if IAM encourage off siding and using the full width of country roads to gain a view like RoSPA.
I'm not keen on doing it but it seems RoSPA are.
Just wondered if IAM are the same?
PostPosted: 14:48 - 10 Nov 2015    Post subject: Reply with quote
Does it matter?
If you think it helps, then do it. If you don't, don't.
BBR
PostPosted: 14:52 - 10 Nov 2015    Post subject: Reply with quote
stinkwheel wrote:
Does it matter?
Yes if I want to pass my test
PostPosted: 15:19 - 10 Nov 2015    Post subject: Reply with quote
Then that comes down to what your particular observer thinks.
My vague recollection is that even Roadcraft has stopped recommending it now because of the number of coppers that ended up embedded in the front of oncoming vehicles. Turns out that habitually moving towards where the danger is likely to be in order to see it coming isn't always the winning combination that it might appear.
If you're being expected to ride in a way that you disagree then you can always just walk (or ride) away from the course.
Unless you need the ticket. Blood biker? Thinking
MCN
PostPosted: 15:28 - 10 Nov 2015    Post subject: Reply with quote
Tests: For tests they will show you, the testee (that sound's like one bollock), what is required by the tester's to satisfy the opinion of their board/clique.
What is shown and what they require doesn't make it better.
Who drives/rides like they did for their test? Embarassed
The advice is to ride/drive and use the road to best advantage.
The caveat there is to do so safely.
If it doesn't sound/look safe then don't do it.
Unless you can mitigate the/any risk/s.
It's a bit like the 'right of way' syndrome.
Perhaps one had the 'right of way' but that right does hee-haw to help push one's wheelchair whenever one's right is ignored by another.
arthurmo
PostPosted: 15:31 - 10 Nov 2015    Post subject: Reply with quote
I'm doing the IAM now and the mantra seems to be you never surrender safety over position. Sounds good until your interpretation of this clashes with your observer. For me it's being in the gutter on a right hander in autumn full of wet leaves and other crap.
ducati mutleystrada
Triumph Thruxton old and knackered just like the owner
Marlin
PostPosted: 15:43 - 10 Nov 2015    Post subject: Re: Offsiding on country roads Reply with quote
I believe IAM currently discourage this on two grounds:
1. It can cause confusion and erratic behaviour in oncoming traffic (even if you know you're fine to get back safely to your side, they might decide to go there as well).
2. Routinely off siding increases the risk that you do it when you don't have enough time to react and get back should the view show you something coming.
[Edit: I'm not sure 2 can be an official position as you shouldn't be doing anything "routinely" and the point equally applies to not being near the middle of the road for low visibility lefts where you wouldn't have time to react to oncoming traffic cutting the corner.]
That said, I off side when I judge it appropriate (both safe and useful).
T.C
PostPosted: 18:40 - 10 Nov 2015    Post subject: Reply with quote
As a RoSPA examiner (and former IAM examiner) I can assure you that RoSPA do not approve of offsiding since the Police abolished teaching it back in the 90's.
If someone offsides in front of me on test, I mark them down.....
It is better to arrive 30 seconds late in this world, than 30 years early in the next
Undinist
PostPosted: 18:56 - 10 Nov 2015    Post subject: Reply with quote
Hmmm. The discouragement of offsiding is news to me - I was taught it in the early '80s and have been doing it ever since. What was the IAM policy in 2002? I took my test then, and can't remember if I offsided. I'm sure I would have done if there'd been an opportunity.
Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S
trevor saxe-coburg-gotha
PostPosted: 19:13 - 10 Nov 2015    Post subject: Re: Offsiding on country roads Reply with quote
Current IAM guidance on this regarding unmarked roads varies by group. Guidance at my branch is to use three quarters of an unmarked road. If you don't, you will be marked down when testing.
On marked roads, at 40mph or over, position 3 for left handers.
When wet, choose the driest line.
However, I'm surprised you don't know this if you've been taking observed rides. It's one of the first points addressed.
Undinist
PostPosted: 19:20 - 10 Nov 2015    Post subject: Reply with quote
What's position 3?
PostPosted: 19:58 - 10 Nov 2015    Post subject: Reply with quote
The offside position.
MCN
PostPosted: 20:07 - 10 Nov 2015    Post subject: Reply with quote
Don't be redickuluss.
Hardly anyone fully understands the offside rule. Rolling Eyes
Very Happy
MCN
PostPosted: 20:10 - 10 Nov 2015    Post subject: Reply with quote
The feckin 80s? Shocked
We still were on carburetors then. Smile
This is some clue as to why keeping abreest of current trends is advised.
But some peeps get their A1 A2 or woteva and believe they are now a driver/rider. Smile
Amber Phoenix
PostPosted: 20:11 - 10 Nov 2015    Post subject: Re: Offsiding on country roads Reply with quote
This first point is exactly how I was pulled up by my IAM test examiner back in June. Lost a mark or two for it and recommended on left handers, with poor visibility, sacrifice some sight (and thus lower speed accordingly) and hug the left a bit.
Having seen a few close calls on ride outs where people have gone wide or way other on right and had to hop back over to left in a hurry. And personally, I'm always seen other cars head on, cutting the corner slightly and over the white line, thus I'd rather (now at least) stick left than put myself where I could encounter some head on...
And what's wrong with carbs?! I'm still on carbs, was still having fun balancing them last weekend. Smile
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
MCN
PostPosted: 20:19 - 10 Nov 2015    Post subject: Re: Offsiding on country roads Reply with quote
Eggzackery. What's wrong wiv 'em?
Nothing.
(Apart from the inability to precisely meter fuel)
Baat.... what was wrong with Horses and then Steam? Wink
We're heading for Lectric soon. (I seen it on Star Trek.)
JP7
PostPosted: 21:01 - 10 Nov 2015    Post subject: Reply with quote
I was formerly an IAM observer and was told not to train or allow offsiding. "Leave it to the police", was our guidance on the matter.
However, on my police driver training it was actively encouraged, to improve view and position round a corner. I use it, but carefully.
PostPosted: 21:07 - 10 Nov 2015    Post subject: Reply with quote
Here's why I'm suspicious of it. The aim is to improve your sight round the bend. This is because in The System of Motorbike Control you should always be able to stop safely (on your own side of the road) in the distance that you can see to be clear. Or put another way, if you can see further, you can carry more speed.
Remember, The System is designed for bike coppers to make progress. You can achieve exactly the same "stop safely" outcome simply by staying on the left side and reducing speed a bit. You're on the right in order to maintain a higher "safe" speed. (Alternatively, you're over there but going slowly, which is at best pointless, at worst harmful).
What you're looking out for is a stationary or slow moving hazard on the left hand side of the road. Things on the right side, well, sure, you need to be looking for them, but they're not hazards unless they cross to the left. I mean, if you'd stayed on the left. But you didn't. So now you've made them hazards too.
Bike is you, going fast enough that you can stop in the distance that you can see to be clear (dotted line), which is just behind the red car. The red car is the stopped-in-the-road hazard that you were looking out for (emerging tractor, box of kittens), the white van is bouncing off his limiter while phoning a customer to tell him that he can't be round until a week on Tuesday, best case.
https://i.imgur.com/sXzaUhm.png
Half a second later, you spot the red car, which you're approaching at a speed that allows to you (just) stop before you hit it. Huzzah for The System.
You also spot the van which is approaching you at "fit in one more job today" speeds.
He (perhaps) sees some maniac way over on his side of the road, approaching at collision speed.
What happens next? What does the van do? What use is your "in the distance I can see to be clear" calculation now? In what way have you improved your safety? You've created a completely unnecessary lethal outcome that you now need to avoid, and you cannot do so by braking alone because you'd followed The System and set your speed based on a stationary hazard.
In fact, you now have to avoid both vehicles, which means braking hard to a stop while swerving left, and hoping White Van Man doesn't panic and try to move to avoid you.
This is an unlikely scenario, but because of the stopped car, not the van that you've turned into a hazard through your actions. I meet a lot more oncoming traffic than boxes of kittens in the road.
Rebuttals?
PostPosted: 22:52 - 10 Nov 2015    Post subject: Reply with quote
I do find it funny that people pass their test, begrudgingly so... they then choose to sit another test that doesn't actually matter and complain about that also.
Ride and aim around the cars. 50/50
PostPosted: 22:57 - 10 Nov 2015    Post subject: Reply with quote
Or by staying at home, of course!
There's a few cases I might use something similar - more likely on roads I know where two cars can't fit side by side.
As I've gone on about enough times, on my bike safe the cop did this. At one point I saw him go to the right of an oncoming car while I smugly hugged the inside at a slower pace having predicted just that sort of thing.
Later I got the impression that oncoming cars some distance away felt rather intimidated by the cop riding directly towards them in their lane.
ScaredyCat
PostPosted: 23:26 - 10 Nov 2015    Post subject: Reply with quote
I was with you all the way up to this bit. Come for a ride round here, people stopping at the side of the road like the red car in your picture is a very common thing. Yes, on blind corners. Usually to take a phone call, which is one step forwards and four backwards.
We also suffer a lot from articulated lorries coming round corners in the middle of the road. Being out on the far right like that is a no-no for me on the roads here. This creates an interesting situation when the two events coincide.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 00:00 - 11 Nov 2015    Post subject: Reply with quote
Rogerborg wrote:
Rebuttals?
Guidance never suggests taking that position so no rebuttal required.
MCN
Off topic: Has the Tef kidnapped the borg's ip addy? Shocked
stevo as b4
PostPosted: 01:02 - 11 Nov 2015    Post subject: Reply with quote
it's not much different to the arguments of:
1, Should you bang down though the gears to lose speed for a hazard, or use the brakes for what they were designed for instead?
2, Big modern sports bike with fat tyres, loads of power etc. Should you try and go apex to apex as much as possible and carry corner speed as high as you dare, or should you slow down much more, slam the bike over in a tight turn much later and get it sat upright and the throttle wide open asap?
It's all pretty irrelevant on the roads?
I used to be a member of the IAM with car's and did a load of training for the ROSPA test too. They used to say the same thing about moving within your lane for best position and view whenever possible.
Nowadays I just drive more over to the left nearly all the time, especially when in traffic in case a bike or cycle wants to come past on the outside. The same applies in reverse if your in the outside lane, I always go as close to the central reservation as possible, to make a big gap between the lanes, for anyone that wants or needs it?
Teflon-Mike
tl;dr
PostPosted: 03:36 - 11 Nov 2015    Post subject: Reply with quote
No
The last post was made 10 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 6
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 137.6 Kb
