Brake Piston Seals?
FlubbaBubba
PostPosted: 17:55 - 11 Nov 2015    Post subject: Brake Piston Seals? Reply with quote
The rear brake caliper is pissing fluid everywere an i need new seals as i cant find a piston and seal kit for the bike.
Would it be ok using 34mm ID piston seals on a 35mm OD piston?
Any help would be much appreciated, thanks.
Robby
Dirty Old Man
PostPosted: 18:01 - 11 Nov 2015    Post subject: Reply with quote
I wouldn't, and I'm usually quite risk tolerant with my brakes.
If you say which bike, someone will probably embarrass you by very quickly finding what you're looking for.
FlubbaBubba
PostPosted: 20:21 - 11 Nov 2015    Post subject: Reply with quote
Its a 2005 aprilia mx 125 and i have spent about 2 hours in total looking for a piston and seal kit an i cant seem to find any for it so good luck.
lukamon
PostPosted: 21:11 - 11 Nov 2015    Post subject: Reply with quote
https://www.ultimateparts.net/aprilia/a.php?n=AP8133727-Brake-caliper-rev.-kit-Rear-brake-caliper-Aprilia-MX-125-SuperMotard-2004,2005,2006-Aprilia-Parts-and-Spares-Genuine-OEM&i=340763
£10?
killa wrote: Im an ass man myself
FlubbaBubba
PostPosted: 22:43 - 11 Nov 2015    Post subject: Reply with quote
£10?
I found them earlier but if i put new seals on a worn piston wont they just leak as there made to fit a new piston?
PostPosted: 23:47 - 11 Nov 2015    Post subject: Reply with quote
Pistons don't wear unless they're badly corroded. Clean them up without removing any material, clean out the grooves in the pots, fit standard sized seals and you should be good.
Tdibs
PostPosted: 01:27 - 12 Nov 2015    Post subject: Reply with quote
FlubbaBubba wrote:
£10?
If the wear is really bad then you are correct, but most likely you will be able to polish them back up flush.
The last post was made 10 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 53.29 Kb
