CBF125 so low in oil it does not touch the dip stick!
daifuco
PostPosted: 12:35 - 12 Nov 2015    Post subject: CBF125 so low in oil it does not touch the dip stick! Reply with quote
I bought a bottle of oil (I didnt even have one). I need to top up some oil but I dont want to put too much!
How much should I put before checking the oil level with the stick? Is it advisable to check the oil while cold?
I need to get the little CBF125 working before it gets its due service!
CBF125 - CB600F Hornet '12
mudcow007
PostPosted: 12:42 - 12 Nov 2015    Post subject: Reply with quote
how much does the bike hold?
*edit* 1.1 litres supposedly
if its empty, stick half a litre in an recheck
you need to check when its cold as when you come in from a run the oil is still all over the engine, letting it cool drops it back into the sump (what you are measuring)
grr666
PostPosted: 13:06 - 12 Nov 2015    Post subject: Reply with quote
Is bike on side stand?
PostPosted: 13:16 - 12 Nov 2015    Post subject: Reply with quote
My dads old Triumph Trophy has a Max line on the dipstick but also another line 2-3" down saying "1 pint to full" This makes it very easy to know how much to add. I don't know why modern bikes do not do this.
MCN
PostPosted: 15:34 - 12 Nov 2015    Post subject: Reply with quote
Honda have a way of checking did-stick oil level.
The dip stick is unscrewed.
Wipe off any oil on the dip-stick.
Put the dip-stick back in but do not screw it in.
Pull it out and check the oil is in the hatched area.
Cold engine cold oil the oil should reach the top of the hatched area.
The area between top (High) and bottom (Low) is the safe 'range'. It is not required to add oil. Below this mark there is danger/risk of oil starvation.
Above the mark there is danger/risk of heavy oil consumption and if extreme engine damage.
There may be an issue of checking level on or off the stand but you will have to check your handbook for that or search the Net.
The last post was made 10 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 48.68 Kb
