Yam 125 WR Wont Start After A Morning Of Riding.
SteveAbz
PostPosted: 16:23 - 12 Nov 2015    Post subject: Yam 125 WR Wont Start After A Morning Of Riding. Reply with quote
Hi there,
Yamaha WR125X
So , just got back in from a great ride with a friend. The bike was fine, started every time (Maybe with a little hesitation) and ran fine. Got it into the garage, was letting it cool down and it just turned off.. went to turn it back on just to make sure it was alright and no sound or anything when I press the start button.
I have lights, dash led display works and all the check lights come on and go off as should. Just no starter noise and nothing on button press. It was fine, now its broken.
Any help would be really appreciated. Thinking the starter but not where to start of checking that.
Thanks
Steve
MCN
PostPosted: 16:25 - 12 Nov 2015    Post subject: Reply with quote
Kill Switch in Off position.
Bike in Gear or rather, the interlock switch of side stand is dirty/faulty and making 'in-gear' signal to the starter system.
Battery fooked or battery connections loose/dirty.
Not imposibru for a fault to just happen as-if-by-magic. It is a reason why stuff needs continuous maintenance.
SteveAbz
PostPosted: 16:35 - 12 Nov 2015    Post subject: Reply with quote
I've left it in the garage and am out now. But I think your spot on with the kill switch.. defo thinks its in neutral and that would explain why it killed itself for no reason also. Will keep you posted, thank you sir!
PostPosted: 16:43 - 12 Nov 2015    Post subject: Re: Yam 125 WR Wont Start After A Morning Of Riding. Reply with quote
What do you mean by this?
SteveAbz
PostPosted: 16:48 - 12 Nov 2015    Post subject: Reply with quote
I came home, stopped. waiting for the garage door to open. Once open i rode it in. Sat on it for about 10 seconds just letting it tick over(for no real reason) and it just cut out. Stopped running. Gone. It was in neutral with the stand up.
MCN
PostPosted: 17:06 - 12 Nov 2015    Post subject: Reply with quote
"It was running and cut out" I never readed post fully. Embarassed
Hopefully it's not an overheating issue.
Or low fuel.
But check the switches first and then worry about the more difficult stuff.
PostPosted: 17:30 - 12 Nov 2015    Post subject: Reply with quote
Don't just let it idle for no reason.
Idling can/will...
Drain the battery
Foul the plugs
Overheat the bike.
MCN
PostPosted: 17:51 - 12 Nov 2015    Post subject: Reply with quote
Idling can/will...
Drain the battery
Foul the plugs
Overheat the bike.
Waste Diesel. Smile
The last post was made 10 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 56.94 Kb
