| Cureforsanity |
 Cureforsanity L Plate Warrior
 Posted: 19:30 - 15 Nov 2015 Post subject: Newbie with a passion for buying crap which doesn't work.... |
Now then, howdo and ey up from Lancashire.
Some have mid life crises where they go out and buy an Harley and get a tattoo, others a teenage nymphomaniac and a convertible 911....
I on the other hand am still in my first childhood but have recently found myself attracted to (or maybe attracting) crap that doesn't work.
Usually I can fix it, but after a long long time without a bike I fancied getting another stroker and gradually trading up to the LC350 which I sold for peanuts in the early 90's.
I've started with a YB100 (Please don't laugh!) which has a good spark but won't fire.
I've cleaned the carb out so fuel gets to the cylinder but still no joy. I assume because I'm getting a spark at the plug with the ignition switched on but no battery connected it should still start?
Head's coming off tomorrow to check the piston is intact with it obviously being such a highly tuned race item.....
Any ideas to stop my foolishness turning into stupidity like last week when I had to do a silly dance outside the pub after eating a full bag of ghost chilli flavoured pork scratchings? |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| almostthere |
 almostthere Traffic Copper
 Posted: 19:53 - 15 Nov 2015 Post subject: crap |
I tend to buy piles of junk that I can see potential in, once I've bought it I usually can't be arsed to do much with it and leave it in the back garden, doesn't annoy the wife one bit  ____________________ Beer, It's the reason I get up every afternoon
www.mfairco.uk |
| stickybackbob |
 stickybackbob Trackday Trickster
| Ariel Badger |
 Ariel Badger Super Spammer
| wodge |
 wodge Nitrous Nuisance
| Robby |
 Robby Dirty Old Man
| Iain. |
 Iain. Could Be A Chat Bot
| A100man |
 A100man World Chat Champion
 Posted: 14:29 - 16 Nov 2015 Post subject: |
| Robby wrote: | ..
You have a spark. Is the spark happening at the right time? If it has points, are they in the right position. If it uses a hall effect sensor off the flywheel, has the flywheel slipped on the crank?
Compression needs testing.
The easiest way to tell if it going to run or not is to try bump starting it down a long hill. |
I think Robby's on teh money here. I wanted a YB100 (cos it was cheaper than a fizz) but ended up with the almost identical A100 Suzuki. Timing was the issue with mine. There was/is only limited adjustmenst on the stator plate and if the points cam follower is too worn you cannot compensate enough. Strongly recommend new points are a starting point.
Good luck ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Cureforsanity |
 Posted: 21:17 - 16 Nov 2015 Post subject: |
Cheers chaps, I'll stick a new plug on it and sort a battery in the morning.
I now have a new problem though, my partner in grime decided to strip & clean the carb on Saturday after I did it on Thursday and now it's leaking petrol from the float bowl overflow.
He doesn't reckon he's left anything out but it sounds to me like he's tipped it upside down and lost the spring from under the float valve so now it's stuck open....
Ah well, at least I can get a repair kit but now it seems the starting of the thing may have been put back a few days.....  |
| Cureforsanity |
 Posted: 16:54 - 22 Nov 2015 Post subject: |
Well.
What can I say?
Bought a new spark plug, BP7HS (the one in the hole was a BP6S) and it started first kick!
Admittedly it blew a smokescreen out of the back to begin with but after that it was quite clean!
Now it didn't run for too long and it doesn't respond to the throttle or choke really and occasionally it has a tendancy to scream up the rev range so I knocked it off but I think a carb overhaul will do it a power of good.
At least I know it runs now and the 'pipe is gas tight and quiet.....
Hmmmm, I don't like quiet pipes
Sooooooooooo Flog it as is or go with my original idea and make it into a bit of a 'racer'? Admittedly I've found a pair of period Tomaselli clip ons so I'll assume the latter  |
The last post was made 10 years, 341 days ago. Instead of replying here, would creating a new thread be more useful? |
