Change CBF 600 Tail lights to LED
MenuBoy
PostPosted: 18:30 - 16 Nov 2015    Post subject: Change CBF 600 Tail lights to LED Reply with quote
Hello, could all or anyone please let me know how to change the tail lights on my bike. Not the bulbs but the whole assy. I'm putting in the LED brighter ones.
Its my first bike, yes I'm 40! My mod1 is in 2 weeks. What I know about bikes you can write on a match stick. Its a 2010 model with ABS. Its just took me an hour to change the front side lights!!!
Do I have to take every thing off or is it a simple task.
As a side note its got two panniers and a back box, will it look better if I leave these off.
Appreciated for any help.
Why put off until tomorrow when you can do it the day after.
MenuBoy
PostPosted: 19:39 - 16 Nov 2015    Post subject: Reply with quote
Thanks for the optimism, shall I change the tail lights on the Bandit to the much brighter say I say safer LEDs also?
zark
PostPosted: 19:44 - 16 Nov 2015    Post subject: Reply with quote
I tried an LED tail lamp - incorporated the brake light too, and had a cut out in the lens to also do the number plate.
It was rubbish, stopped working for no apparent reason and i binned it.
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
MenuBoy
PostPosted: 20:46 - 16 Nov 2015    Post subject: Reply with quote
This is the new type that's e stamped. It's plug n play. No cut out as reg plate is positioned lower. What year was your CBF? Can you remember how you changed it? For clicking mad I can't even find how you take them off just to change for another set, nether mind LEDs.
Thanks
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
MenuBoy
PostPosted: 08:50 - 17 Nov 2015    Post subject: Reply with quote
Like a Haynes manual? No but thanks for the idea, I'll pick one up today.
Parson
PostPosted: 09:32 - 17 Nov 2015    Post subject: Reply with quote
You should be able to find one online.
Then gsx650F - Now VFR800F
Rogue_Shadow
PostPosted: 14:39 - 17 Nov 2015    Post subject: Reply with quote
If your planning to do the Indicators, they will need to incorporate a resistor otherwise it's all aboard the strobe train Dance!
Otherwise it's fairly self explanatory, plenty of guides on Youtube no doubt.
If you do buy a cheap kit, expect to repair it every other Monday.
MenuBoy
PostPosted: 15:02 - 17 Nov 2015    Post subject: Reply with quote
Thanks. It cost just over a hundred, is not that cheap is it? Also ready ordered a resistor. I'm a LED nut in so I converted all my vans even with extra spotters! Search YT hi and low, also trawled the interweb and found zilch. Going crack on with it one bolt at a time and see how far I get before the eureka moment happens.
MenuBoy
PostPosted: 09:04 - 19 Nov 2015    Post subject: Reply with quote
Job done.
Panniers off
Back box off
Back seat off
Plastic cover with seat lock off
Side fairings running under seat off
Four self tapper screws holding cluster off
Unplug cluster
Then reverse for reassembly
New cluster has indicator resistors within so no need to fit extras.
I have HISS so indicators had to be connected to flash when activated.
30 minutes to change.
goto10
PostPosted: 10:35 - 19 Nov 2015    Post subject: Reply with quote
MenuBoy wrote:
Job done.
Panniers off
Back box off
Back seat off
Unplug cluster
Before and after pics are mandatory.
MenuBoy
PostPosted: 11:26 - 21 Nov 2015    Post subject: Reply with quote
Will put pics up today, only finished pics though.
The last post was made 10 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 74.54 Kb
