| fergul |
 fergul L Plate Warrior
 Posted: 13:40 - 22 Nov 2015 Post subject: It won't start (02 hornet) |
got my hornet 600 a week ago managed to get out on it once but now it just won't fire changed the plugs and battery but that didn't work. My only other thought is the fuels gone bad as it had been stood for a while, or the one I'm dreading is blocked carbs.
I couldn't find where to post an introduction jobby.
Cheers
Ferg |
| Vincent |
 Vincent Banned
| MCN |
 MCN Super Spammer
 Posted: 14:20 - 22 Nov 2015 Post subject: |
Welcome to here.
Do you know if the fuel system has an inline filter fitted?
If it has been 'stood' then any 'stuff' that the filter matrix has trapped may have developed into an impenetrable mush/slime.
Key off or turn the fuel off if it has a valve/cock
Remove the filter and try to flush it out by shoogle-ing it in some clean petrol.
Reconnect to the tank end of the fuel hose.
Point the open end into the container you used to wash the filter.
Turn on ignition or open the fuel tap/valve/cock and check if fuel flows from the open end. It should be a good stream as opposed to a drip or trickle.
Reconnect to the open end of the filter to the engine end of the fuel line.
Try to start.
Fuel will go off but not so much that it will prevent an engine being started.
I may loose some detonation qualities but not so bad that it would need replaced.
Maybe a good practice to replace fuel that's been standing for several years.
Petrol doesn't suffer as much from storage as Diesel fuel does. But Diesel seems to suffer more due to moisture.
When storing any fuel system the recommendation is to fill tanks to max to reduce the air space. Tanks are vented to allow fuel to run out and to prevent stress from thermal expansion etc.
As the fuel cools it reduces volume which allows the atmosphere to push air into the tank. Moisture in the air can then condense on cold surfaces in the tank. When the fuel heats up and expands the air is pushed out again but the condensed moisture isn't an eventually drops, runs down to the bottom of the tank.
Because of this issue most tanks incorporate a 'stand' pipe device where the outlet is raised a little above the lowest point of the tank.
And why it can be a problem when you run a tank to empty. Fuel keeps any water/shit on the bottom but without the weight of the fuel on it the shit can be sooked into the system.
And FYI
Jobby
Be careful.
 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Islander |
 Islander World Chat Champion
| MCN |
 MCN Super Spammer
| fergul |
| MCN |
 MCN Super Spammer
| fergul |
The last post was made 10 years, 332 days ago. Instead of replying here, would creating a new thread be more useful? |
