bent clutch lever and foot shifter
bigdom86
PostPosted: 14:47 - 24 Nov 2015    Post subject: bent clutch lever and foot shifter Reply with quote
Hi guys,had an off today. Think I locked the front wheel and dropped,went so quick not 100%.
Clutch lever is bent but rideable as is the foot shifter,how easy are these to bend back? Its a Honda cbr125 2015. Are they easy to fit?
Cheers Thumbs Up Laughing
Paint diagram.will follow tonight
PostPosted: 15:05 - 24 Nov 2015    Post subject: Reply with quote
Piece of pie to replace. Just bend them (slowly and as little as possible) back into shape so that it's ridable while you source replacements, I've done a CBR at the roadside using a biggish spanner for leverage, you'll be fine.
bigdom86
PostPosted: 15:48 - 24 Nov 2015    Post subject: Reply with quote
Was going to have a go with some pliers tonight but worried it will crack?
DrSnoosnoo
PostPosted: 16:18 - 24 Nov 2015    Post subject: Reply with quote
With too much bending it will break (the gear shifter). The clutch lever will snap if you try to bend it (more than likely). Be slow, "gentle" adjustments. If it's rideable, I'd be inclined to get on David Silver spares and get a new one ordered. Ride until it arrives and fit in 10 minutes.
bigdom86
PostPosted: 16:30 - 24 Nov 2015    Post subject: re Reply with quote
Think I will ride till I get spares incase cheers. Bit worried it snaps as I need it for work.
What's the official name for the foot shifter? As can't find it on eBay.
Will take a look at David silvers cheers
smallfrowne
PostPosted: 17:58 - 24 Nov 2015    Post subject: Reply with quote
Foot shifter also known as a gear lever. Quite a few turn up on an ebay search, about £25 for a cbr125r
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
Matt B
PostPosted: 20:40 - 24 Nov 2015    Post subject: Reply with quote
Funny things levers, they bend really well in one direction (when you bin the bike), but rarely want to bend the other way (when you want to save a few quid).
bigdom86
PostPosted: 22:57 - 24 Nov 2015    Post subject: re Reply with quote
just bought the parts, think i will play it safe and just replace them as cheap enough, would not want to be riding and it suddenly snaps off
MCN
PostPosted: 01:37 - 25 Nov 2015    Post subject: Reply with quote
If you whip it off and straighten it a little at a time. BUT:
Alumininininum wil 'Work Harden' if you bend it. (It is already work hardened by the drop)
Rub some hand soap on the lever and warm it up in a gas flame carefully so the soap isn't in the flame (it will burn).
When the heat conducts along the lever to the soap it will blacken the soap.
This is the temperature when the metal becomes annealed. and can be bent again.
Remove from flame and allow to cool slowly, even wrapping in a non flammable cloth.
Straighten a bit more and repeat as required.
talkToTheHat
PostPosted: 03:54 - 25 Nov 2015    Post subject: Reply with quote
Do the above. A big vice might work better than beating back into shape with a hammer. Use jaw protectors.
Bandit. does. everything.
DrDonnyBrago
PostPosted: 11:03 - 25 Nov 2015    Post subject: Reply with quote
Can straighten them without cracking if you heat them up with a blowtorch first. Rub a bar of soap on it, when the soap turns black you are very close to the point where the lever can be bent, prob needs just a bit more heat and it'll bend nicely. Can reanneal aluminium sump plug washers in the same way should you find yourself without.
If you overdo the heat, it will melt before it glows red so your lever could become a puddle on the garage floor.
The last post was made 10 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.06 - MySQL Queries: 15 - Page Size: 67.46 Kb
