Ballpark price for internal wall removal
dabigginger
PostPosted: 22:53 - 24 Nov 2015    Post subject: Ballpark price for internal wall removal Reply with quote
The previous owner of our house converted part of the double garage into a study. As part of this, the floor in the study area was raised a few inches to match the height of the rest of the house and two internal plasterboard walls, about 10 ft and 8ft were fitted. One of these walls has a 2-gang electrical socket, so this would need removing.
There's no point in getting anyone over to quote for this until I get some spare cash together, so I'm wondering if there are anyone in the trade on here who might be able to give me a rough idea on what I should budget for this.
Thanks in advance!
Itchy
PostPosted: 23:02 - 24 Nov 2015    Post subject: Reply with quote
Go to your local library (if it's still there). There will be a book about how much you should expect to pay for certain kinds of work by professionals.
It usually gives a high, low and median figure.
PostPosted: 23:05 - 24 Nov 2015    Post subject: Reply with quote
Internal plasterboard walls are a DIY job. Wink
oldpink
PostPosted: 23:07 - 24 Nov 2015    Post subject: Reply with quote
this ^^
tip it out if its not load bearing just tear it down
PostPosted: 23:38 - 24 Nov 2015    Post subject: Reply with quote
MrGs1 wrote:
I could take down in two minutes with a sledge hammer.
You're not special any idiot could do that. A decent mattock man and a labourer could dismantle it, get it in the skip and tidied up in not much longer and it wouldn't look like some oaf had driven through with a bulldozer.
OP: If you can get the electrics moved do the rest yourself. To do it by-the-book properly would cost hundreds. Plasterboard is controlled waste and mustn't go into a general rubbish skip. Snap it up, put into bin bags and take it to your nearest waste transfer yard with a couple of twenties in your hand they might get rid of it all for cash. Expect there to be rockwool type insulation between the boards.
duhawkz
PostPosted: 23:44 - 24 Nov 2015    Post subject: Reply with quote
oldpink wrote:
this ^^
not necessarily, some stud walls can be load bearing. probably best to check first.
[/quote]
PostPosted: 23:48 - 24 Nov 2015    Post subject: Reply with quote
You check by removing it and seeing what happens next. Wink
The OP says the walls were fitted as part of the study area which was converted from being a double garage. From that I assume that they're not going to be load bearing walls.
oldpink
PostPosted: 23:53 - 24 Nov 2015    Post subject: Reply with quote
duhawkz wrote:
oldpink wrote:
this ^^
I worked in the building trade for 20 years and have never came across a timber frame & plasterboard wall that was load bearing
thats what RSJ's concrete lintels and brick walls are for Thumbs Up
dabigginger
Sounds like it could be worth a punt. I'm 99% sure it won't be load bearing. Although it was put up many years after the house was built, I don't know if it's supporting the ceiling in any way. I honestly don't know if the ceiling was done at the same time as the house or when the wall was put up.
Are there any people you can get to confirm one way or another? It's obviously in any builders interest to say it needs them to do the job...
dabigginger
PostPosted: 23:55 - 24 Nov 2015    Post subject: Reply with quote
hmmmnz
PostPosted: 00:04 - 25 Nov 2015    Post subject: Reply with quote
i ve just this job almost exactly at my brother in laws house,
except the previous owners converted the whole double garage into a gym complete with hot tub, steam room and sauna,
false floors, and all sorts of she-nanagans.
turned it back into a large single garage, with a laundry and a "wine store" took more time to rip everything out than what it did to put up a new stud wall, and re-plasterboard every thing,
so in short, while timber and plasterboard walls can be load bearing,
in a garage its almost certainly not,
and its not really the done thing in the uk, although new builds are heading that way.
just knock down the wall. pull the plasterboard off first, then you'll see how its constructed.
the humans are dead
I kick arse for the lord
Diggs
PostPosted: 02:12 - 25 Nov 2015    Post subject: Reply with quote
What's above it? If the garage roof has joists then as long as the joists still span the garage, the stud walls won't perform any structural function.
If you want to take it down yourself, first make sure the socket has no power to it, then take a lump-hammer to the plasterboard. Once this is off and the insulation is out of the way you can tackle the studding. Either get jiggy with the lump-hammer and a wrecking-bar or use a drill/driver if you want to make less mess and don't want to disturb the floor/ceiling joists which it should be screwed to.
Depending on where you live, a builder will probably charge you one day's labour at 150-250 quid, plus another 50 for disposing of the waste.
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
MCN
PostPosted: 10:54 - 25 Nov 2015    Post subject: Reply with quote
£1000 you would take more than 121 seconds.
bugeye_bob
PostPosted: 13:06 - 25 Nov 2015    Post subject: Reply with quote
How was the floor raised ?
yen_powell
PostPosted: 15:05 - 25 Nov 2015    Post subject: Reply with quote
Good question.
Garages that are attached to a house are supposed to have a floor 6 inches lower than the house. Has someone carefully put in a removable wooden floor or poured concrete straight on top of the garage floor which will leave you with a step in the middle of the room.
XT1200Z and a DR350 in bits
Rockhopper
PostPosted: 18:11 - 25 Nov 2015    Post subject: Reply with quote
If the previous owner did it properly to comply with Building Regulations then he should have insulated the floor which perhaps explains the increase in height?
Current building regs say that instead of the 100mm step that used to be required you can have the garage floor sloping towards the door. Also the door from the garage into the house needs to be a fire door.
dabigginger
PostPosted: 00:30 - 26 Nov 2015    Post subject: Reply with quote
I think it's just joists, then the usual roof beams. If a builder could do it in a day, I might be tempted to get then to do it just to avoid any hassle. I know a good plasterer who be able to her a nice finish over what is left behind.
Thanks Smile
dabigginger
PostPosted: 00:33 - 26 Nov 2015    Post subject: Reply with quote
I know there are chip board panels underneath the carpet. I have a funny feeling there's a load of polystyrene underneath this to insulate this. I suspect the chipboard is resting on some kind of frame booked to the concrete base.
bugeye_bob
PostPosted: 00:54 - 26 Nov 2015    Post subject: Reply with quote
order a skip and get the sledge hammer out, isolate the electric supply for that socket (is there no light in that part ?) and worry once the wall is down, coil up socket once wall is down and call sparky to remove.
dabigginger
PostPosted: 19:18 - 31 Dec 2015    Post subject: Reply with quote
So, I decided to go ahead with the sledge hammer and crowbar. It's taken about 15-20 hours to get it to this stage and I'm nearly there now. I can't believe how massive it is. Results so far:
https://i18.photobucket.com/albums/b105/dabigginger/Stu/G40Work/IMGP7607.jpg
https://i18.photobucket.com/albums/b105/dabigginger/Stu/G40Work/IMGP7606.jpg
Thanks for the advice Smile
PostPosted: 19:29 - 31 Dec 2015    Post subject: Reply with quote
Was that crack there before you sledge hammered?
dabigginger
PostPosted: 19:53 - 31 Dec 2015    Post subject: Reply with quote
Laughing I found out a few weeks ago one of my neighbours is a retired builder. He had a little look up in the roof space a couple of weeks back and confirmed it wasn't a load bearing wall.
MCN
PostPosted: 01:24 - 01 Jan 2016    Post subject: Reply with quote
That 'Trinket Tray' in the corner isn't very 'load bearing' now either. Smile
Cool Bob the Builder job.
The last post was made 10 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.51 - MySQL Queries: 13 - Page Size: 124.74 Kb
