 skyebiker Derestricted Danger
 hmmmnz Super Spammer
 unitynotsocri... Banned
 Posted: 19:23 - 28 Nov 2015 Post subject: |
id thoroughly check the engine and frame numbers. eaarly engines being 6 volt,then 12 volt with fake cdi ( cdi trigger for points) . The later ones included electric start and kill switch so if you are starting from a engine/frame rebuild id start with the engne type and build your wiring from there and also note you need to get the right switchgear and clocks to go with your engine. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
