Grease for packing shock bearings/linkage? Marine or Moly?
Amber Phoenix
PostPosted: 14:08 - 25 Nov 2015    Post subject: Grease for packing shock bearings/linkage? Marine or Moly? Reply with quote
Just had an absolute nightmare removing a shock off a CBF500, lower bearing well and truly seized. Had to be drilled and hacksawed out. All sorted now, with new bearing etc, but I don't want a repeat.
So, I've got a tube of Lith grease and I've got a tub of Granville White Marine Grease. Kind of figured the latter would be best - water proof and salt water resistant etc. But I've read many opt for Molybdenum Disulphide grease.
So, would the Marine grease suffice or am I better off picking up some Moly grease?
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
MCN
PostPosted: 14:20 - 25 Nov 2015    Post subject: Reply with quote
We tried W/P on boat trailer wheel bearings etc. but there is no superb benefit.
The solution is to have a method to replenish the grease.
Sealed for life components for get this.
ACF-50 produce a grease that 'they say' is water/salt proof.
Corrosion protection stuff.
We use a product called Denso Tape to protect bare metal off-shore. It takes a bit of time and some practice to get it on where it stays but I haven't found much else as alternative. It can be removed and replaced several times too.
Oldie
PostPosted: 14:39 - 25 Nov 2015    Post subject: Reply with quote
Can't see any particular benefit in using Moly in a shock bearing. Marine will be fine.
PostPosted: 11:06 - 26 Nov 2015    Post subject: Reply with quote
I only use waterproof grease on shock linkage bearings. Not like it's going to get hot or run at high speed like a wheel bearing.
The last post was made 10 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 40.11 Kb
