| enj1996 |
 enj1996 Two Stroke Sniffer
| Vincent |
 Vincent Banned
 Posted: 16:49 - 26 Nov 2015 Post subject: |
Try Wemoto.com for the parts but shop around. It depends how good a chain you want how much it will cost. Beware of cheap chain, it can be a false economy. Somewhere between £45 and £85 I'd have thought.
https://www.wemoto.com/products/transmission
Not too difficult to sort out yourself, it depends how much spannering you've done previously. There are a couple of slightly tricky bits, tightening the front sprocket for eg, but straightforward enough. Do a search on here, there shoud be loads of threads about it, and on youtube too. Also, get yourself a manual, they make things a lot easier. I get one whenever I buy a new vehicle, most workshop manuals you can pick up cheap, used, some you can download for free.
If you're location is listed, someone on here may offer help, which is good - just make sure that they know more than you if so  ____________________ Space Is Deep |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 17:57 - 26 Nov 2015 Post subject: |
Yamaha OEM O ring chain & sprockets about £110 Needs riveting
Did HD Chain non O ring & JTS Sprockets about £50 Split link
Make sure chain is HD, will say on box., I got about 12k on non o ring chain.
Easy to change, but be careful of rear sprocket carrier bolts, made of cheese, I torqued to correct amount and 2 sheared, replaced with proper steel bolts. Split link goes on one way, make sure its right. ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| enj1996 |
| Vincent |
 Vincent Banned
 Posted: 00:21 - 27 Nov 2015 Post subject: |
I wouldn't bother riveting the ends of the chain, a split link will be fine for your bike if installed correctly. Check to see if there's one with the chain before paying for it. If you get a mega cheapo chain, use a split link from a reputable manufacturer.
Somewhere else for your bits:-
https://patternparts.net/#
Or
https://patternparts.net/chains-sprockets-drive-belts ____________________ Space Is Deep |
| CALLUM KELLY |
 CALLUM KELLY L Plate Warrior
| Keir |
 Keir World Chat Champion
 Posted: 11:30 - 27 Nov 2015 Post subject: |
£25 + delivery for a DID HD and sprocket kit from M&P ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
The last post was made 10 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
