| cresad |
 cresad Nova Slayer
| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 15:49 - 26 Nov 2015 Post subject: |
Have a look at my post
hope it helps
https://www.bikechatforums.com/viewtopic.php?t=308433 ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,, |
| smallfrowne |
 smallfrowne Scooby Slapper
 Posted: 16:04 - 26 Nov 2015 Post subject: |
What's the voltage at higher revs (with headlight on), say at 4 or 5k rpm? Sounds fine without the headlight on though.
Have you tested the voltage using the standard bulb? Although they probably won't fit the headlight if it's now using H4 fitment hmmm. The normal bulb is probably around 35W not 55W. Sadly the wee stator might not be able to juice up the uprated bulb Back to candle light for you!
Something else you could try though if it can't handle the 60/55W bulb and the 22/5W tail lamp: you could try using a lower powered LED tail lamp.
So instead of 60W + 22W = 82W you'd have
60W + 3W (a rough guess) = 63W which is more like the standard of 35W + 22W = 57W.
Might give the stator more of a chance to achieve a semi-reasonable charging voltage, these little stators don't have much capacity over what they needed at design time.
Never tried it myself though, no idea if LED tail bulbs are even any good, but maybe worth a go.
First things first and all that I'd start by testing it with the old bulb and seeing if it charges ok, then doing some further checks on the rectifier as per the other thread if it does not.
Bikes r fun! ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| Vincent |
 Vincent Banned
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| monkeybiker |
 monkeybiker World Chat Champion
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
 Posted: 19:05 - 26 Nov 2015 Post subject: |
Me too, 10.7v standing charge, winter eh  ____________________ DRZ400-SM
FZS600 |
| MCN |
 MCN Super Spammer
| cresad |
 cresad Nova Slayer
| Vincent |
 Vincent Banned
| Ariel Badger |
 Ariel Badger Super Spammer
| Vincent |
 Vincent Banned
| Ariel Badger |
| WD Forte |
 WD Forte World Chat Champion
| cresad |
 cresad Nova Slayer
| smallfrowne |
 Posted: 18:26 - 29 Nov 2015 Post subject: |
Ah bugger, not so simple then. How did you check the stator, ohms between the output leads? Been a while since I tested a stator - can't remember what a good value should be sorry.
I'd be tempted to check to see if the AC voltage was the same between the windings, I've had a few burn out before where one of the windings was toast and at an obviously different voltage to the others. If the voltage is similar across the outputs it should be ok though and it will probably be the rectifier.
I found this flow chart, https://www.electrosport.com/media/pdf/fault-finding-diagram.pdf which might be of a bit of use to aid in fault finding. But might not relate exactly to your bike. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| cresad |
 cresad Nova Slayer
| WD Forte |
| cresad |
 cresad Nova Slayer
| cresad |
 cresad Nova Slayer
The last post was made 10 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
