Clunky Bandit Arse
mudcow007
PostPosted: 10:03 - 27 Nov 2015    Post subject: Clunky Bandit Arse Reply with quote
The way I have to get my bike out in the morning is wheel the front wheel out of the back door an then physically lift the back wheel around a corner....sounds complicated an it is - an Bandit's aint known to be light
Anyways this morning lifting the bike an its clunked when i lifted it, sounds stupid but it was like a mechanical clunk.
Should i be worried?
Was thinking its possibly just the rear shock/ swingarm dropping down?
will get it on the track stand tonight
temeluchus
PostPosted: 11:18 - 27 Nov 2015    Post subject: Reply with quote
Paddock stand isn't any good for sussing if the arse end is loose.
You need to jack the thing up or if fitted, put it on the centre stand, so that the rear wheel is in the air. Try and lift the rear wheel and see if there is any free play.
PostPosted: 11:57 - 27 Nov 2015    Post subject: Reply with quote
Do you notice the back squirming under power? That's how I noticed my Linkage bearings were shagged.
It ain't a cheap job either, as said you need the arse off the ground to see where the movement s.
mudcow007
PostPosted: 13:13 - 27 Nov 2015    Post subject: Reply with quote
funny you should mention the squirming thing, on the way home yesterday going around a corner it felt like it had a soft tyre, like it wanted to turn different.
Checked pressure this morning an they are a-ok
Shocked
will go an have a look at the caliper an stuff now
cheers all Thumbs Up
MCN
PostPosted: 18:31 - 27 Nov 2015    Post subject: Reply with quote
Loose chain hitting the frame.
UnknownStuntm...
PostPosted: 18:34 - 27 Nov 2015    Post subject: Reply with quote
Wheel bearing starting to go? You can and should check that on a paddock stand...
Noxious89123
PostPosted: 01:40 - 28 Nov 2015    Post subject: Reply with quote
Is the spindle/axle nut tight, or is it just the adjusters keeping it in place? Shocked
mudcow007
PostPosted: 13:41 - 14 Mar 2016    Post subject: Reply with quote
sorry to dig this back up but its happening again.
noticed it today both under power an under braking - feels weird like a flat tyre
Was on paddocks last night wheel bearings seem ok
chain is a-ok aswell
I dont have a centre stand, but went ghetto an lifted the bike on the side stand an everything "seems" ok....will try an figure out how to lift the bike without a stand
basically could it only be swing arm bearings, wheel bearings ?
PostPosted: 14:13 - 14 Mar 2016    Post subject: Reply with quote
Buy an abba stand or similar make any work on the bike much easier.
Solidly get the rear end up and unloaded and have a wiggle, it will be obvious what is shagged.
yen_powell
PostPosted: 14:53 - 14 Mar 2016    Post subject: Reply with quote
Get the bike up on side stand and axle stand under right hand footrest hanger so the rear wheel is off the ground.
Get a long bar, broom handle or similar. Use it under the back wheel to try and lift it. If there is any play in the rear linkages you will see and hear it straight away. By moving it up and down you should also see which linkage is shot.
XT1200Z and a DR350 in bits
The last post was made 10 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 68.68 Kb
