Am i going to need a new fuel tap?
AzzA1990
PostPosted: 23:17 - 27 Nov 2015    Post subject: Am i going to need a new fuel tap? Reply with quote
Hi guys
Went to pull the tank off my little RXS100 today and as i gave the fuel pipe a little tug the brass nipple that the fuel line goes onto actually came out of the fuel tap! i went to place it back in and it's just very wobbly it doesn't go back in tightly, the brass nipple when it came out had a plastic type seal over it that was mangled i couldn't save it, what do you guys think? easier to get a new after-market tap? I've attached a photo that hopefully you'll be able to see Smile[img][/img]
Suntan Sid
PostPosted: 00:08 - 28 Nov 2015    Post subject: Reply with quote
If the nipple was sealed and held in place with a plastic type O-ring, then surely replacing the O-ring will fix the problem!
I'd be trying that before buying a new tap.
If a new O-ring doesn't fix it, as an absolute last resort, you could glue it back in place, with plastic metal.
Noxious89123
PostPosted: 00:34 - 28 Nov 2015    Post subject: Reply with quote
Looks like it has a groove for an o-ring, but I should hope it's held in by more than just friction!
Is it missing an internal circlip from the body of the tap?
PostPosted: 08:46 - 28 Nov 2015    Post subject: Reply with quote
I have done that before. They are just glued in so either buy some fuel-safe loctite or believe it or not it's a perfect job for JB Weld, which is 100% fuel resistant once fully cured.
redeem ouzzer
PostPosted: 09:14 - 28 Nov 2015    Post subject: Reply with quote
^^this
I had one pull out on a twin exit 350 tap and used a good quality industrial epoxy to put it back in, never had an issue.
AzzA1990
PostPosted: 09:31 - 28 Nov 2015    Post subject: Reply with quote
Thanks for the replies! i am going to have a proper look at it today whilst i have the time and see what i can do
MCN
PostPosted: 10:01 - 28 Nov 2015    Post subject: Reply with quote
Don't hold your camera/phone as close to the subject. The lens cannot focus properly. You can probably see where some of the background is in focus but the area in question is blurred. So there is little useful detail suitable for inspection.
Ariel Badger
PostPosted: 10:17 - 28 Nov 2015    Post subject: Reply with quote
I know the film for a digital camera can be expensive but if the first picture does not work take a second one please.
The last post was made 10 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 57.03 Kb
