fazer running issues
hmmmnz
PostPosted: 09:01 - 30 Nov 2015    Post subject: fazer running issues Reply with quote
Hey guys
My fzs600 fazer runs perfectly at idle and if i blip the throttle it'll rev smoothly,
But when I'm riding it, it'll run on 3 cylinders until about 3800rpm before it'll come back on to 4 cylinders. And rev smoothly through to red line.
Initially I thought it was carb related, mainly because it was running way worse when I got it, I cleaned the carbs which made it better. It had a missing spring and o ring on the pilot?/idle Screw.
Any way I bought another set of carbs, which I sonic cleaned, and replaced the jets, and made sure they were balanced after I refitted yesterday. I made sure all the needles and diaphragms were good and were moving freely.
It's certainly made it run even smoother. But the low rpm 3 cylinder issue is still there.
Where do you reckon I should look next.
the humans are dead
I kick arse for the lord
DrSnoosnoo
PostPosted: 09:28 - 30 Nov 2015    Post subject: Re: fazer running issues Reply with quote
hmmmnz wrote:
Hey guys
Plugs, caps and HT leads?
hmmmnz
PostPosted: 09:35 - 30 Nov 2015    Post subject: Reply with quote
Mmmm. I'll give it a go.
Just seems a bit weird
that it's only in the low revs that it fails.
the humans are dead
DrSnoosnoo
PostPosted: 09:38 - 30 Nov 2015    Post subject: Reply with quote
I'm no expert but you've done one bit that controls the firing, so could be a dodgy plug or connection seems a logical place to check Thumbs Up
Amber Phoenix
PostPosted: 09:57 - 30 Nov 2015    Post subject: Re: fazer running issues Reply with quote
Yep, that's where I'd be looking next. And whilst you're there pop a multi-metre on the coils to check they're sound too.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
hmmmnz
PostPosted: 13:07 - 30 Nov 2015    Post subject: Reply with quote
Ordered a new set of plugs and caps.
Had already trimmed the wires and tested the coils.
the humans are dead
Hahadumball
PostPosted: 17:32 - 30 Nov 2015    Post subject: Reply with quote
as foc-u post says, plug + cap, i had the same
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
hmmmnz
PostPosted: 19:20 - 30 Nov 2015    Post subject: Reply with quote
ill keep you kids updated,
fingers crossed its as easy as that,
Very Happy
failing that ill look at valve clearences.
the humans are dead
Luckyfish13
PostPosted: 20:43 - 30 Nov 2015    Post subject: Reply with quote
Check the compression while your there bro!
Andy_Pagin
PostPosted: 20:53 - 01 Dec 2015    Post subject: Reply with quote
A dodgy connection can disconnect temporarily due to vibrating at it's resonant frequency which would only happen at certain revs.
I had a similar problem with a Landrover with a loosely riveted LT wire on the coil. At certain speeds it cut out. An ex-army RAC mechanic explained this to me, tapped the rivet with a hammer, it never played-up again.
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 71.93 Kb
