anti-dazzle? visor
bigdom86
PostPosted: 23:55 - 30 Nov 2015    Post subject: anti-dazzle? visor Reply with quote
not sure if its a word "anti-dazzle", but can you get visor inserts that stop that light effect you get in the rain when looking through a visor. like when your in a car in the rain and someone is sitting infront of you with their brakes on
kramdra
PostPosted: 00:02 - 01 Dec 2015    Post subject: Reply with quote
I have been wondering if a polarising filter/visor could be made to remove light from oncoming cars. That would be brilliant, but any glasses usually tinted.
monkeybiker
PostPosted: 00:07 - 01 Dec 2015    Post subject: Reply with quote
Make sure your visor is clean and has no scratches.
MCN
PostPosted: 01:11 - 01 Dec 2015    Post subject: Reply with quote
^^^ This. End of thread. Smile
brains_t
PostPosted: 01:27 - 01 Dec 2015    Post subject: Reply with quote
Clean and no scratches doesn't help once the visor is hit with greasy spray from road. I find yellow tint visor or pinlock will help but looking for a better solution.
Kris
PostPosted: 10:20 - 01 Dec 2015    Post subject: Reply with quote
I'm still using a light tint visor. Seems to help with the brightness of oncoming cars what with their headlights aimed at Jupiter.. Rolling Eyes
The dazzle is made worse with water on the visor, have you tried gloves with a visor wipe to keep it clear?
www.prisonplanet.com
iooi
PostPosted: 10:35 - 01 Dec 2015    Post subject: Re: anti-dazzle? visor Reply with quote
In a word "NO"
As the reason for the light effect is the water drops acting as a lens and refracting the light.
The only way to combat it is to keep the visor dry and clean or have a reverse water drop on the inside of the visor Laughing
You still get the same problem in cars. Only its not as bad as the wipers do a good job of keeping the water at bay and you are further away from the cause of the problem. Meaning that the light is scattered further away and a lot less focused.
A polarising filter only works in one direction. So will not stop this effect. Yes it will negate some of it, but not all of it.
bigdom86
PostPosted: 10:40 - 01 Dec 2015    Post subject: re Reply with quote
visor is clean and no cracks, it is only when the rain gets on it, maybe have a look at gloves with a wipe
Kawasaki Jimbo
PostPosted: 13:48 - 01 Dec 2015    Post subject: Reply with quote
Not serious suggestions, but interesting anyway;
Spinning disc (still available for karting from Demon Tweeks) or electronic wipers.
PostPosted: 14:27 - 01 Dec 2015    Post subject: Reply with quote
We have those on ships but they run at 2000rpm to clear the screen Laughing Can't see an air powered one working!!!
https://www.navitech.co.uk/content/images/weather-tight-clear-view.jpg
Triumph Trophy Launch Edition
MCN
PostPosted: 14:35 - 01 Dec 2015    Post subject: Re: anti-dazzle? visor Reply with quote
iooi wrote:
In a word "NO"
Nice try iooi Thumbs Up but the physics is wasted on some folks. Sad
If we/mankind hadn't invented fire and the wheel then this problem wouldn't even exist.
iooi
PostPosted: 16:12 - 01 Dec 2015    Post subject: Re: anti-dazzle? visor Reply with quote
If only Adam hadn't eaten that apple Laughing
andyscooter
PostPosted: 16:42 - 01 Dec 2015    Post subject: Reply with quote
finish work earlier so it isn't dark :up:hth
Alpineandy
PostPosted: 18:56 - 01 Dec 2015    Post subject: Reply with quote
I understand that they now make rainx (or similar) for plastic which in theory would help with the water dispersal. I gather the version for glass windscreens doesn't work on visors but haven't tried it.
I'd recommend a yellow tinted visor (or glasses) for anyone doing much riding (or driving) at night. If I have to do many miles at night I tend to get headlamp 'dazzle' headaches if I don't use yellow glasses.
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
MCN
PostPosted: 21:38 - 01 Dec 2015    Post subject: Reply with quote
Any tint will reduce the amount of light you can see.
Nomad Z
PostPosted: 22:13 - 01 Dec 2015    Post subject: Reply with quote
The amount of reduction depends not only on the density of the tint, but on the colour of the tint and the colour of the external objects being looked at. Matching colours (like yellow object and yellow visor) will be slightly darker, while complementary colours (yellow visor, blue object) will look much darker, with varying amounts of darkening in between. The net effect is to increase chromatic contrast.
Given that our eyes have an in-built automatic exposure system, better contrast can be more worthwhile than avoiding a slight darkening of the overall scene, although the benefit depends on how dark things are overall, and how much the pupils can open up to compensate.
Kaya75
PostPosted: 23:54 - 01 Dec 2015    Post subject: Reply with quote
Pin lock helps stop inside misting,
You can get a rubber wiper to fit over the finger of glove about a fiver from anywhere, net or really real shop
MCN
PostPosted: 04:21 - 02 Dec 2015    Post subject: Reply with quote
It's nothing to do with contrast. If there's not much light then there will not be much contrast. The important thing is to see as much light as possible.
https://www.laramyk.com/resources/education/dispensing/the-dangers-of-night-driving-glasses/] Yellow Tint [/url]
The Frogs used to use yellow headlamps for the same unfounded reasons. It was stopped after science proved the theory was garbage.
Alpineandy
PostPosted: 13:38 - 02 Dec 2015    Post subject: Reply with quote
You can refer to it as garbage but as far as I'm concerned It works. It may reduce the overall amount of light somewhat but it reduces the 'dazzle' effect substantially which is what gives me the headaches.
If it doesn't work for you or for 95% of the driving population, so be it. But it works for me. Cool
Kawasaki Jimbo
PostPosted: 13:57 - 02 Dec 2015    Post subject: Reply with quote
The link doesn't actually debunk the idea though, it just points out that whilst amber lenses filter out some short (blue) wavelengths (so you're receiving less information) this may be offset in certain circumstances by reducing glare or dazzle. Seeing as much light as possible isn't always good.
I guess in a foggy, illuminated city-scape a yellow lens/visor can be helpful, but elsewhere you might be more concerned about spotting the blue wavelengths on the edge of your pool of light.
Yellow light triggers both the red and the green cones in the human eye making it the colour we are most sensitive to, but then the way the brain processes the information is probably influential too. Maybe this is where contrast comes in?
Firkit
PostPosted: 13:59 - 02 Dec 2015    Post subject: Reply with quote
Has nobody come up with a visor that employs one of those future-science-today hydrophobic materials yet? Seems like a perfect application and shouldn't be prohibitively expensive.
Alpineandy
PostPosted: 14:06 - 02 Dec 2015    Post subject: Reply with quote
Lots of visor rain repellent sprays around (on the bay). Not sure if they work.....
I do use RainX on the car (which I think works but only when lots of care is taken when applying it) but I heard that stuff wasn't any good on plastic visors. Although someone told me a few days back that they now do a version for plastic/visors.
PostPosted: 15:41 - 02 Dec 2015    Post subject: Reply with quote
Honest Officer, the reason I was doing 150mph was that I have found rain clears off my visor better at that speed than 70. Thumbs Up
The last post was made 10 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 130.59 Kb
