Citroen Relay (Campervan) - Anyone Familiar?
STONEY!
PostPosted: 12:02 - 01 Dec 2015    Post subject: Reply with quote
The vacuum pipe for the turbo is common to be knocked off causing a lack of power, you usually just put it back on and away you go!
bugeye_bob
PostPosted: 18:24 - 01 Dec 2015    Post subject: Reply with quote
as long as it doesnt leak air it will be fine Thumbs Up
STONEY!
PostPosted: 00:19 - 03 Dec 2015    Post subject: Reply with quote
Try some stuff call Q-bond if you can, its a powder/glue combination and is very strong/versatile.
andyscooter
PostPosted: 08:54 - 03 Dec 2015    Post subject: Reply with quote
older ones used to have problems with the front window cracking a lot
dads got through about three a year (was caused by the van flexing because of the size of the screen (but was a boxer)also had one at work that did the same
also had a reoccurring problem with a fuel pump on dads that got swapped with another at his work and then seemed ok
The last post was made 10 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 63.69 Kb
