Little bit of advice for an unseasoned rider.
InkedMuttley
PostPosted: 19:50 - 01 Dec 2015    Post subject: Little bit of advice for an unseasoned rider. Reply with quote
I'm a new member haven't posted in an introduction section but everything you might want to know is in my public bio.
I'm fairly new to biking I didn't take my CBT until last December and only had a bike (WK Wasp 125) for a couple of months before I realised that it had an appetite for eating cylinders and cylinder heads so I got rid. The bug bit again in October and I purchased another bike a CPI GTR, looks like a cross between a bike and a scooter, it was originally a 50cc but when I bought it it had a 70cc cylinder upgrade on it and no MOT. On the way to the MOT the first time it broke down 9 times in 8 miles before I finally thought sod it and took it home in a van.
Sorted it to the best of my ability and tried to take it for an MOT again and it broke down less than half a mile from home and couldn't get it going again. Took it to my good lady's home and left it in her garage and have stripped the engine, upon stripping it I discovered that the ring was very polished on the sides, there is a lot of the original honing still visible but there's also a little gouge in the cylinder wall. I thought it may work with a new ring so have done it but it still isn't getting any compression (about 5psi) so I've finally bit the bullet and have a new cylinder kit on the way which I'm hoping it works.
However I found when we stripped it down that for some reason someone had stuck a steel dowel in the oil feed pipe for the autolube system (it's a 2 smoke), so the person before me had been running it on Premix. I now have 2 or 3 questions that I need answering.
1: With a brand new cylinder is it likely to run knowing the damage from the last cylinder or am I going to need to rebuild the whole engine?
2: Is the fact that I'd been running it on straight petrol (didn't know autolube was disabled) to blame
3: I've decided to run premix myself as it says on aguide that the standard oil pump wouldn't be able to put out enough oil to compensate for the increased cylinder capacity but at what ratio would it need to be roughly, it's a 9 litre fuel tank.
Sorry for the long winded post but I dearly hope one of you wonderful people might be able to help me, and greetings from sunny (not) Lincolnshire!
Oh and this isn't my bike but mine is identical
https://scooterunderground.ca/products/gas/images/CPI_GTR_Blue_2008.jpg
If you like me, we'll get on fine...If you don't, then just form an orderly queue and join the rest of my haters.
Ariel Badger
PostPosted: 20:18 - 01 Dec 2015    Post subject: Reply with quote
If it has rum without oil you may have damaged the big end, little end and main bearings as well as the crank seal. did previous ouner not say it was on premix?
InkedMuttley
PostPosted: 20:36 - 01 Dec 2015    Post subject: Reply with quote
No there was a bit of confusion about the bike to be honest it was bought from one bloke, the lad who bought it took a loan off his friend and gave him the bike as security and then told him to fuck off as he didn't want the bike anyway then muggins here bought the bike.
But nobody at any time told me it was premix they'd been running.
Burnzy1989
PostPosted: 21:14 - 01 Dec 2015    Post subject: Reply with quote
I would run it at 32/1 so it's works out to 150mls of oil to 5 liters of petrol. But what you must check is the jetting is corects for running premix as it will cause it to run lean. you will find you could run the bike again but will end up with rumbling big ends and main bearings. I would rebuild it completely if the bearings have picked up on the races or siesed they are scrap .
InkedMuttley
PostPosted: 00:22 - 02 Dec 2015    Post subject: Reply with quote
The engine turns freely and even after replacing the rings it seems fine just no compression was told by a bike mechanic that the bottom end should be okay. How would I check the jetting on it to see whether it is the right one for premix?
Ariel Badger
PostPosted: 00:37 - 02 Dec 2015    Post subject: Reply with quote
As you do not seem happy with the advice freely given here why not ask your bike mechanic?
InkedMuttley
PostPosted: 00:45 - 02 Dec 2015    Post subject: Reply with quote
I've not said that I'm not happy with the advice at all, far from it in fact I'm actually delighted that someone's actually given me a ratio that they'd use instead of the responses I've had elsewhere which were more along the lines of "How the fuck should I know?".
As for my bike mechanic it was a mechanic that had come out to me to check it out, I don't have a bike mechanic as such now I'm simply playing things by ear now.
PostPosted: 08:39 - 02 Dec 2015    Post subject: Reply with quote
Do you not think it's a wiser idea to shift that on and grab a CG or YBR? They don't really break down. This is a now tuned 70cc ped which you seem to know a lot about given your sig. 18000rpm crank isn't needed so just get shot of it and buy a reliable 4 stroke.
WD Forte
PostPosted: 13:03 - 02 Dec 2015    Post subject: Reply with quote
Yeah, what he said.
Dump it and get a 4T hack
bikers smell of wee
FBSF
PostPosted: 13:19 - 02 Dec 2015    Post subject: Reply with quote
Having had experiences of an RD125LC stroker that cost me an absolute fortune when I was a teenager, due to it being "tuned" and running lean, I'd cut your losses. I had to get shot of it once the engine had holed it's third piston, despite going up to a 25% bigger main jet.
It'd also be a damn site cheaper to insure a bog-standard 125 bike or scooter rather than your modded-to-the-moon 'ped...you have mentioned all of the mods to your insurance, haven't you...? Confused You don't want to end up with an IN10 for no valid insurance - it'll cripple you for years.
A 4t scooter will happily do 60-65mph, will do a shed load more to the gallon and generally won't blow up anywhere near as often!
InkedMuttley
PostPosted: 14:16 - 02 Dec 2015    Post subject: Reply with quote
Trust me I'd love to get a CG125 or similar but I'm just not in a position financially to do so at the minute, instead I'm having to stick to this until I can save enough cash to get something that is more fit for the purpose. I've always wanted a CG125 in fact I found one on the Bay of E a couple days ago that had been chopped and modded to look like an old cafe racer and very nice it was too but unfortunately I'm on my arse at the minute and it seems that even CG125 projects just lately are fetching top dollar.
So for now I'm stuck with this shitter and I've just got to put up with it for the time being. As for insurance yes everything is declared with my insurance company cost me a few pennies extra but at least I'm not going to end up getting shit on if I need to make a claim because I've changed a sticker or something. Been in that boat before with a car, never again.
PostPosted: 17:55 - 02 Dec 2015    Post subject: Reply with quote
But does your logbook say 50cc or 70cc... The 2 are different.
You are able to sell that ped to fund a 125 you know. You need about 600 quid. That ped will sell for a few hundred to some pikey go fast init lad. Ebay it.
Tierbirdy
PostPosted: 23:26 - 02 Dec 2015    Post subject: Reply with quote
Youve bought a knackered lemon of bastardised parts, probably by some spotty 16yr old YOOF who wanted to show off his hardcore modding skillz and race his mates on a "BANGIN 70SEESEES OF POWAH MATEY, PIGS WONT EVA NO LIKE"
You say you cant afford a decent bike and stuck trying to fix this, but its going to be a total money pit trying to get it working.
Set fire to it, claim it on insurance, buy a cheap banger of a 4T 125 that'll still be more reliable. Razz
Ariel Badger
PostPosted: 23:51 - 02 Dec 2015    Post subject: Reply with quote
You say it is insured and all mods declared, what insurance level do you have TP, TPF&T, Full Comp?
PostPosted: 23:58 - 02 Dec 2015    Post subject: Re: Little bit of advice for an unseasoned rider. Reply with quote
It should, but as Ariel Badger said above it's been short on lube to the roller bearings. Did you buy a standard barrel or another 70cc kit?
Probably. The oil in the petrol lubricates the cylinder walls. Petrol on the other hand is quite a good degreaser so does the opposite.
[/quote]
Sounds like a load of codswallop. The oil pumps can usually be adjusted to pump way too much oil. The reason it was plugged is probably because a previous owner let it run out then didn't prime it and assumed that it wasn't working, or just listened to crap advice like the above and thought they could improve on a time-proven design by sloshing some oil about in a pot of fuel.
Burnzy1989
PostPosted: 00:01 - 03 Dec 2015    Post subject: Reply with quote
Looks like you best off selling it as said above. I can asure you it will end up costing you more than it is worth, it request a full rebuild and while your stripping it down I bet you will end up finding more wrong with it that right. A cg 125 is not a bad potter about but is ok if your not a speed freak. Or save your money and do your full bike test as it seems people who are 16 17 seem to be unlucky as there are no more 125s left as the big four have stopped production of two strokes. A Kwak kmx 125 or a yam dt 125 a honda nsr 125 or a suzuki dr 125 4 popper . I do feel sorry your generation never had the luck of getting cheap good bikes.
InkedMuttley
PostPosted: 08:14 - 03 Dec 2015    Post subject: Reply with quote
Yes mate it's fully comp with BikeSure I believe I'm with with a value of£800 on the policy I believe but my excessis a fair old whack unfortunately (£100 voluntary £250 compulsory)
And Burnzy1989 I'm assuming the 1989 is your year of birth, if that's the case "My generation" is older than yours I'm 29 years young buddy.
Burnzy1989
PostPosted: 09:11 - 03 Dec 2015    Post subject: Reply with quote
Hahaha lol yha it is. I wouldn't mess about with it to be honest if I were you I would spend as little on it get it running and flog it as you will get more for it running. Then use the money to do you full test it cost roughly 500 to 600 pounds. It's worth doing best thing I did and is not as hard as you think pluss bigger bikes are alot more fun.
Ariel Badger
PostPosted: 19:52 - 03 Dec 2015    Post subject: Reply with quote
A shame about the excess, I was going to recommend F.
InkedMuttley
PostPosted: 03:51 - 04 Dec 2015    Post subject: Reply with quote
Okay I'm officially lost. I've got the whole thing rebuilt it's got a brand new top end and has brand new gaskets all over it, there's also a brand new spark plug, brand new coolant, brand new oil...everything just about is brand new.
There's a good strong spark, the carb and cylinder is getting fuel and oil as it should...and it still won't start, it's clearly got compression because the fuel is being expelled from the spark plug hole when I checked for a spark but it still won't go. Admittedly I have managed to snap a bolt for the exhaust (enough left to get stillsons on it to wind it back out and replace it)
Would the exhaust not seating properly stop it from building up enough compression to start it or am I absolutely fucked and the thing is never gunna go again?
Burnzy1989
PostPosted: 08:22 - 04 Dec 2015    Post subject: Reply with quote
It should start with out the exhaust but fundamentaly it needs to he gas tight being a 2 stroke as the exhaust plays a big game of making power.
What you must do next is check your reed block and make sure the reeds are not broken in any way .
Then do a compression test and see what sort of presume is there.
If all is ok then make sure your carb is clean and there is no dirt or water in the bowle.
And did you check the ring gaps when you rebuilt the top end and did you make sure you put the piston in the right way .
Or did you put loads of oil on everything thing when you built it up.
PostPosted: 08:24 - 04 Dec 2015    Post subject: Reply with quote
PLEASE STOP THROWING MONEY AT THIS.
YOU WILL HAVE FUNDS FOR A 4 STROKE 125 IN NO TIME.
InkedMuttley
PostPosted: 13:35 - 04 Dec 2015    Post subject: Reply with quote
No I've barely used any oil at all, just a smear on the gudgeon pin and a tiny smear around the bottom rim of the cylinder. Piston was put in the same as it was before with the arrow pointing down to the exhaust port, baring in mind it was in the same orientation as the piston that was removed, as for reeds I can't even figure out where they would be (sorry if I seem a novice but reeds aren't known to me I'm used to rebuilding V8's)
stirlinggaz
PostPosted: 17:11 - 04 Dec 2015    Post subject: Reply with quote
hi,
you should have smothered everything with 2t oil before re-assembly (piston etc) its common practice.
it burns off, once you get it running.
an air tight exhaust is critical in a 2t.
do a compression test, with a decent compression tester & post results (remember to hold throttle wide open to get an accurate psi) do it a couple of tines & get an average.
if you have decent compression :
mix up some petrol & 2t oil at the ratios mentioned earlier & make yourself a remote fuel tank. (empty fairy liquid bottle & length of fuel hose does the job)
connect it up to the carb.
also put some 2t oil in the oil tank.
stick a new spark plug in & test oil pump/bleed it whilst its running off the remote fuel tank/pre-mix.
btw reeds live in between carb & cylinder (google 2t motorcycle reed block/reeds for image)
cheers,
GAZ
Copycat73
PostPosted: 19:39 - 04 Dec 2015    Post subject: Reply with quote
the only sensible suggestion i have is to double check the ignition timing.. Thumbs Up
caveat emptor
The last post was made 10 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 134.23 Kb
