| sakean99 |
 sakean99 Two Stroke Sniffer
| Dom_ |
 Dom_ Points Mean Prizes
 Posted: 23:00 - 06 Feb 2005 Post subject: |
I find that on my rs50, it runs 90 front and 100 rear, which is bloody skinny. Over white lines mine seems to do the same as you are describing, i just put it down to thin tyres and the white line. But i'm unsure now  |
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 23:16 - 06 Feb 2005 Post subject: |
Have you tried the testing the back/front wheels for side ways movement while on say a paddock stand. If there's a sign of sideways movement or sound of grinding coming from the wheels and, if so, then it's a case of replacing the wheel bearings with a set of new ones.
Also, maybe the swing arm needs to be topped up with grease.
Here's a link for finding part no.'s so as to get the correct OEM replacement parts for your bike.
https://www.bikebandit.com/partsbandit/oem~submit_from_stage~1~section_dept_id~1.asp
Or you might like this site for 2nd hand parts;
https://www.cheshiremotorcyclesalvage.com/acatalog/
Yes, at times white lines particularly when you're filtering through traffic when the road is very wet along with cat eyes on road. I personally hate those road repairs done after laying cable for NTL because when you go around corners and the surface happens to be raised in the middle of the repair it's a freakin' nuisance!
 Posted: 23:20 - 06 Feb 2005 Post subject: |
They do tend to be sensitive to it. However check the tyre pressures carefully (and also check with the tyre maker as they might specify quite a different tyre pressure for that bike than the bike maker does). Check for play in the wheel bearings, steering head bearing and also the rear suspension linkages. Swinging arm bearings are possible, but they rarely seem to wear. Also have a play with the suspension settings, and probably best to set them back to standard as a good starting point.
| Guest |
 Guest Brolly Dolly
| BLOFLY 636 |
 BLOFLY 636 Brolly Dolly
 Posted: 10:52 - 07 Feb 2005 Post subject: |
what keith said my old ZZR 250 did that when I would tip it from one side to another, felt like the rear tyre was sliding out like Gary Macoy style but it turned out to be the rear wheel bearing on it's way out  ____________________ Those bloody footpegs......they ought to do away with em! |
| sakean99 |
 Posted: 20:07 - 07 Feb 2005 Post subject: Hmmm, that's given me something to think about! |
Thanks everyone, lots of useful ideas there. I have tried to flex the rear suspension when on the main stand & it did all feel very solid. Tyre pressures seems a likely one & I will check them next.
I'm due an MOT soon (hence low price of bike!! ) so I'm trying to sus out problems before I get slammed by Mr Local Bike Shop. ____________________ Born again Bikers can do it again, & again, & again! |
| bish777 |
 bish777 World Chat Champion
| sakean99 |
 Posted: 22:39 - 10 Feb 2005 Post subject: Update |
Well, I couldn't find anything wrong & neither did the local bike shop. I now have a new MOT Thanks for all your help. I guess I am just getting more sensitive & nervous as I get older & closer to the grim reaper! Sides of the tyres have hardly ever even got warm - yet! ____________________ Born again Bikers can do it again, & again, & again! |
| Scotsman37 |
| BLOFLY 636 |
 Posted: 00:18 - 11 Feb 2005 Post subject: |
forgive me if this is a stupid question but what exactly is an MOT?  ____________________ Those bloody footpegs......they ought to do away with em! |
| Scotsman37 |
 Posted: 00:30 - 11 Feb 2005 Post subject: |
| BLOFLY 636 |
 Posted: 01:53 - 11 Feb 2005 Post subject: |
oh ok then, here in Western Australia we don't have any of those tests. Just need to renew the license on the bike every 6 or 12 months. On the odd occasion if a traffic copper pulls a bike or car over they may want to inspect the vehicle for any problems such as tyre wear, oil leaks or any other simple to spot problems. If there is a problem, the officer places a Yellow sticker on the windscreen of the car ( I am not sure where the sticker goes on a bike ) and the owner has 3 weeks to rectify the problem/s and return it to a pit inspection for errr, inspection if the vehicle passes the yellow sticker is removed and the vehicle drives or rides away $50 short for the insection. If the vehicle fails then you may get an extension on the 3 weeks limit or you need to hand the plates in and take the vehicle home to fix at your own leisure, when you are ready to have another insection then you must tow the vehicle in and have it inspected and re-licensed  ____________________ Those bloody footpegs......they ought to do away with em! |
| Scotsman37 |
 Posted: 02:14 - 11 Feb 2005 Post subject: |
To get the MOT certificate here in the UK it's a yearly costs of £15 (about $24 aus dollars) starting from 3 years since the bike was new and it has to pass the MOT before the old one expires otherwise like you said take it there by trailer for inspection unless you can find a mechanic to come and inspect it!
On top of that our vehicles require a yearly road tax certificate (disc) to be always displayed on our vehicles and the cost of it depends on the cc of your vehicle can be as high as £60 ( about $96 aus dollars). You can only get the disc if you've got a valid MOT certificate.
Plus the on top of that again we require vehicle insurance which can be as little let say for average £130 ($208) to even as much as £1,000 ($1,600) depending on your personal circumstances and what vehicle you choose! |
| Scotsman37 |
 Posted: 11:57 - 11 Feb 2005 Post subject: |
The value of the Aussie dollar has jumped then because it's always usually sitting at about average $1.60 to the £1. Oh well, my Aussie relatives will be extremely happy !
Queensland and Melbourne |
| BLOFLY 636 |
 Posted: 12:46 - 11 Feb 2005 Post subject: |
| BlueNinja |
 BlueNinja Trackday Trickster
 Posted: 16:11 - 11 Feb 2005 Post subject: |
Hey.
Check if your bike uses a cush drive! it may be worn, this will cause it to pull to one side under acceleration. Fit a new one, (around 20 squids) grease the bearings, axle etc, fit it the rear wheel back, replace split pin, and remember to pump the rear brake pedal before using it again!! this will take up the 'slack' in the brake lines and cylinder.
Should be an easy cheap job  ____________________ Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483 |
The last post was made 21 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
